Need Cam Timing Help #355134
06/22/09 10:08 PM
06/22/09 10:08 PM
Indiana
BM70Dart Offline OP
BM70Dart  Offline OP
Indiana
I've got a 440 with eddy heads compression is around 9.5. The cam is currently installed at 102. Its a lunati 255-259 duration solid lifter with .550 lift. Would it help et to retard it to 106. Car weighs 3300 lbs and has a 5000 converter 3.91 gears and 28" tires. Thanks
Re: Need Cam Timing Help [Re: BM70Dart] #355135
06/23/09 03:53 PM
06/23/09 03:53 PM
organ
maximum entropy Offline
organ
put it where lunati tells you to. that cam seems a bit on the big side for your compression ratio. what's the lda?
Re: Need Cam Timing Help [Re: maximum entropy] #355136
06/23/09 04:57 PM
06/23/09 04:57 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
My vote would be leave it right were it is.
