Re: EBody Fuel Gage Question
[Re: screamindriver]
#354858
06/24/09 09:50 PM
06/24/09 09:50 PM
Challenger 1
Cincinnati, Ohio
And you're probably correct Robert...I'm betting the aftermarket unit just is'nt close to the correct sweep judging by the values that have been stated...Bending the stop won't give that much more on the top end...And since taking out the cluster for caliberation/sender sync is not on the list there's only one quick fix...You need to bend the float arm before it contacts the upper stop...The basic idea would be to bend the arm in a way that would rotate the center stud up further to gain the values you need for a full tank but keep the float in the same general orientation....Now, you may not get it to read completely full without the actual rallye gauge caliberation with the sending unit...but you'll surely get a much more accurate, useable needle sweep and reading...
Bend the arm before the stop. Get your reading down around 10 ohms, then you got it.
[Re: 70VERT]
#354860
06/24/09 10:43 PM
06/24/09 10:43 PM
RapidRobert
You might give Mancini a call & see what Wes thinks. The gauge reading 1/2 full thats WAY off. I could be wrong on this but I dont think you can manipulate the bend enough to correct that kind of error & you shouldn't have to especially for that kind of money.
[Re: 70VERT]
#354865
06/25/09 12:34 AM
06/25/09 12:34 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
dumb question... how much gas is in your tank? or these tests were all done with the sender OUT of the tank? ![](/ubbthreads/images/graemlins/laugh2.gif)
**Photobucket sucks**
[Re: BDW]
#354871
06/25/09 08:09 PM
06/25/09 08:09 PM
Posts: 1,822 Colorado
denfireguy
Colorado
I'm jumping in here late, but sounds like a sender problem. Bending is only going to get you that last little bit. I wouldn't think you're going to make up 1/2 tank.
Good luck
Sorry, I have been away from the board for a while. I also do not think that bending it will help. 14 ohms is what your are going to get no matter where the arm is even if it is bent. The extra 5 ohms is what is giving you the problem. If you can find a 25 ohm, 1 Watt resistor to put in parallel with the sender and ground, you can fix the top end reading but the mid and lower scale readings will not be linear. The only way to fix it is to get a sender that will go down to 9 ohms with the arm fully raised. Putting both senders in the circuit will give you 7 ohms on the line and you should get a full tank indication. It is just not handy having two senders out there. Just throwing that out there for trouble shooting purposes. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: denfireguy]
#354872
06/25/09 09:00 PM
06/25/09 09:00 PM
RapidRobert
Do you still have your 5/16" sending unit & if so check it's ohms & toss it in & see if your gas gauge reads right & if so & before you bend the 3/8" one I'd call mancini again & get a return # & send it back & ask them to evaluate it
