Timing mark jumps @ 2000rpm and above!! What-up? #354809
06/22/09 06:00 PM
06/22/09 06:00 PM
California
70Klassick Offline OP
California
Hello, timing mark is clear 22'int.@800rpm--- then advances smoothly to 36'@2000rpm--- then mark jumps like a beitch!! Timing chain slak is 5'-6'deg.!! Have new tune-up stuff even the coil! Why is mark jumping all over?????
Re: Timing mark jumps @ 2000rpm and above!! What-up? [Re: 70Klassick] #354810
06/22/09 07:04 PM
06/22/09 07:04 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
the answer is in your question...
bad timing chain
I am truckless..
Re: Timing mark jumps @ 2000rpm and above!! What-up? [Re: 340SHORTY] #354811
06/22/09 07:06 PM
06/22/09 07:06 PM
North Chicagoland
N
newbee69 Offline
newbee69  Offline
N
North Chicagoland
bad timing chain
X2
Re: Timing mark jumps @ 2000rpm and above!! What-up? [Re: newbee69] #354812
06/22/09 09:43 PM
06/22/09 09:43 PM
California
California
WOW 2 for 2. What is the tolerance for 440 timing chain? Double roller. I tested by turning crank to TDC-then had someone watch rotor--and I turn crank backwards. No rotor movement till 5deg.maybe 6. Thanks guys!!!
Re: Timing mark jumps @ 2000rpm and above!! What-up? [Re: 70Klassick] #354813
06/23/09 01:05 AM
06/23/09 01:05 AM
The Dalles, OR.
Dusted_Ya Offline
Dusted_Ya  Offline
The Dalles, OR.
That's alot! 2degrees is the most I'll go before replacement. Is there any play in your rotor?
Re: Timing mark jumps @ 2000rpm and above!! What-up? [Re: Dusted_Ya] #354814
06/23/09 02:21 AM
06/23/09 02:21 AM
California
California
2 degs. is all? I read somewhere that said 3-5 is good. 10&up is bad. Rotor does have play,but I don't know how much? What else could make mark jump? Pick-up coil reads 280 ohms. maybe its sending weak signal?
Thanks Kurt
Re: Timing mark jumps @ 2000rpm and above!! What-up? [Re: 70Klassick] #354815
06/30/09 07:17 PM
06/30/09 07:17 PM
California
California
[Edited by Moparts - Keep it clean]!! Turns out..It was the timing light!!
Mark is stable if I use the dail-in advance,say 1- 38deg.for ex. If its on 0deg. mark jumps.WOW- WHO Knew. Will probably do timing chain over the winter thou.
Thanks Guys and Moparts
