removing windshield trim on 69 Dart #354396
06/22/09 08:31 AM
06/22/09 08:31 AM
Minnesota
I
IEAT4DS Offline OP
IEAT4DS  Offline OP
I
Minnesota
Is there a tool to remove the stainless trim around the front and back window? Is there a trick to removing them without damaging the trim or paint? Thank you!!! Scott
Re: removing windshield trim on 69 Dart [Re: IEAT4DS] #354397
06/22/09 09:14 AM
06/22/09 09:14 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
K-D tools sells a trim remover - it looks like a handle with two hooked ends. Idea is to use the hooked end behind the chrome to pull the molding clip toward the windshield.
http://www.denlorstools.com/home/dt1/page_1935_20/kd_tools_kd_2038_window_molding_remover.html
Re: removing windshield trim on 69 Dart [Re: Sixpak] #354398
06/22/09 05:38 PM
06/22/09 05:38 PM
Minnesota
I
IEAT4DS Offline OP
IEAT4DS  Offline OP
I
Minnesota
Thanks sixpak !!! Scott
Re: removing windshield trim on 69 Dart [Re: IEAT4DS] #354399
06/22/09 08:54 PM
06/22/09 08:54 PM
colorado
chargermop Offline
chargermop  Offline
colorado
buy the way taking the trim off an a-body is a PITA, if you dont know what your doing you will ruin the clips and end up pulling the glass or hurting the paint. Try a car at the junk yard first or call the pros....
