Re: Lexan door glass mounting
[Re: dartphil]
#353082
06/20/09 09:35 PM
06/20/09 09:35 PM
Quicktree
[Re: Quicktree]
#353085
06/20/09 09:41 PM
06/20/09 09:41 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
use your glass as the template for the lexan. now you need to form a small diameter metal tube (5/16) to the curvature of the original glass about an inch or so from the outside. now attach it to the lexan with rivits and little clamps.....
I am truckless..
[Re: dvw]
#353090
06/21/09 11:00 AM
06/21/09 11:00 AM
Posts: 52,972 Romeo MI
MR_P_BODY
If you notice that the pro stocks and others have a latch that they close after they close the door, thats to keep the top of the window from moving outward
[Re: MR_P_BODY]
#353091
06/21/09 11:04 AM
06/21/09 11:04 AM
Quicktree
yea and they are expensive. the way mine is done done does the same thing and a lot cheaper.
