electric fuel pump with Edelbrock SB and BB
#352708
06/20/09 02:56 PM
06/20/09 02:56 PM
Posts: 451 Iowa
73ChargerSE440
Iowa
I had a TQ on my 318 cut out when I open it up,so I put a 600 cfm electric choke edelbrock on the car same result, it idles fine, open it up and it cuts out, my buddies thing it is a volume thing. Fuel pump?
67 Ply. Belvedere II 2dr Hardtop
73 Dodge Charger SE 440+6 727 Dana 60 4.10
78 Chrysler Cordoba 400-4 727 9 1/4 3.21
1999 Dodge Diesel 2500 QuadCab Longbox
2004 Dodge Durango HEMI Limited
Re: electric fuel pump with Edelbrock SB and BB
[Re: 73ChargerSE440]
#352709
06/20/09 04:40 PM
06/20/09 04:40 PM
Posts: 451 Iowa
73ChargerSE440
Iowa
for the money is it worth going to an electrical fuel pump?
#352710
06/21/09 03:42 AM
06/21/09 03:42 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I run a Holley red pump on the 440 in my 63 and its the one with built in regulation so no seperate regulator is needed. It holds about 7 psi and supplies more then enough fuel for my mid 11 car. It would work fine on a 318 also but some people say they are to noisey for them. Holley does have a new quiet pump also but I am used to being able to hear my pump so I know its working. Ron
#352712
06/21/09 04:19 AM
06/21/09 04:19 AM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
I'd make sure that is your problem by putting a gauge on and seeing if the pressure drops below 2 psi under full throttle.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
#352713
06/21/09 06:29 AM
06/21/09 06:29 AM
Posts: 511 Jasper, Indiana
fastnos
Jasper, Indiana
Sounds more like a tuning problem. Does it instantly have a problem when you open the secondaries, or did it develop over a period of time? (what I mean about that is does it work fine till it runs all the fuel out of the carb bowls?) Have you went back to the basics and "proved" what is right with the timing, plugs, ect? What color are your plugs right after you think it is running out of fuel? After you "know" what else is right, then work on tweaking whatever is left. Could be a combo of several problems. The more info you can provide, the better we can provide acurate fixes. Let us know what your intial timeing is, then with it fully advanced and at what rpm its all in. Do you have the accelerator pump adjusted so it squirts instantly as soon as you open the throttle?
A True Hybrid: Burns Gas AND Rubber!
[Re: fastnos]
#352714
06/21/09 01:07 PM
06/21/09 01:07 PM
Posts: 451 Iowa
73ChargerSE440
Iowa
You can just watch the gas dry up in the carb, when you crack it open, I will see what my pressure is, tomorrow
