Tappered Axle 8.75 Brake Drum Removal Tricks? #351192
06/18/09 07:03 PM
06/18/09 07:03 PM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
I'm doing the brakes on the 57 Suburban now, have all of the drums and brakes off but the drivers side rear and it is being a stubborn SOB. I have the appropriate puller, have soaked it with penetrating fluid, hammered in on the center to losen rust, etc. No progress, it's frozen solid. Any other 10 cent tricks? I'd prefer not to use a torch unles it's a last resort.
Re: Tappered Axle 8.75 Brake Drum Removal Tricks? [Re: ScottSmith_Harms] #351193
06/18/09 07:05 PM
06/18/09 07:05 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The offending drum
Re: Tappered Axle 8.75 Brake Drum Removal Tricks? [Re: ScottSmith_Harms] #351194
06/18/09 07:26 PM
06/18/09 07:26 PM
Clintwood VA
johnedod Offline
johnedod  Offline
Clintwood VA
Hit the end of the puller with a hammer while it's cranked down tight.
Johnedod
68 Road Runner
71 Road Runner
78 Power Wagon
Re: Tappered Axle 8.75 Brake Drum Removal Tricks? [Re: johnedod] #351195
06/18/09 07:35 PM
06/18/09 07:35 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Just heat it....
You will wind up doing way more damage to it by bearing down on the jackscrew and hammering. I don't even try to do these without the torches at the ready. Everything yields to the fire
MB
Re: Tappered Axle 8.75 Brake Drum Removal Tricks? [Re: ScottSmith_Harms] #351196
06/18/09 07:37 PM
06/18/09 07:37 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If you haven't already done it, as mentioned wack the pressure screw with a BFH.... If all else fails, do the three wheels you have apart, get the car back semi road worthy, reinstall the axle nut on that corner but cotter pin it a couple threads loose & take the car for a drive, bumpy roads are good, also hang a turn loading that corner... It'll come off...
Re: Tappered Axle 8.75 Brake Drum Removal Tricks? [Re: HPMike] #351197
06/18/09 07:43 PM
06/18/09 07:43 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
If it wasn't apart I would recommend (slowly)driving it around a few corners with the nut loose. Usually works.
Leave the gun.......take the Cannoli's....Mike
Re: Tappered Axle 8.75 Brake Drum Removal Tricks? [Re: mike s] #351198
06/18/09 07:53 PM
06/18/09 07:53 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Way ahead of you guys on that one, no worky
The car wasn't drivable when I started and won't be until a few weeks after I'm done, I may leave it on and try later as suggested.
Re: Tappered Axle 8.75 Brake Drum Removal Tricks? [Re: ScottSmith_Harms] #351199
06/18/09 08:09 PM
06/18/09 08:09 PM
Az
Crizila Offline
Crizila  Offline
Az
Heat - after you have exhausted all else. Too much on the jack screw and you will have axle issues.
Fastest 300
Re: Tappered Axle 8.75 Brake Drum Removal Tricks? [Re: Crizila] #351200
06/18/09 09:51 PM
06/18/09 09:51 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
Reminds me of the brake jobs on my 50 Plymouth. Heat, Bang, Crank, and so on and so on! Rotsa Ruck Scotty, you're going to need it.
Re: Tappered Axle 8.75 Brake Drum Removal Tricks? [Re: Classof70Chally] #351201
06/18/09 11:04 PM
06/18/09 11:04 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Got it off! Just needed a bigger hammer............
Re: Tappered Axle 8.75 Brake Drum Removal Tricks? [Re: ScottSmith_Harms] #351202
06/18/09 11:21 PM
06/18/09 11:21 PM
scratchnfotraction Offline
smoke wrench it out and get a modern flage axle set for it
bring it to the 20th century with 21st century beraings and brakes
scratchin
Re: Tappered Axle 8.75 Brake Drum Removal Tricks? [Re: scratchnfotraction] #351203
06/19/09 12:06 AM
06/19/09 12:06 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The old junk actually looked pretty good once I got in there. Once I do these over I doubt I'll live long enough to have another go at it, I think I'll just leave it stock.
Re: Tappered Axle 8.75 Brake Drum Removal Tricks? [Re: ScottSmith_Harms] #351204
06/19/09 09:55 AM
06/19/09 09:55 AM
Az
Crizila Offline
Crizila  Offline
Az
Good Deal. Anti-seize the tapers when you put it back together - just in case you do live long enough.
Fastest 300
Re: Tappered Axle 8.75 Brake Drum Removal Tricks? [Re: ScottSmith_Harms] #351205
06/19/09 11:52 AM
06/19/09 11:52 AM
michigan
black64 Offline
black64  Offline
michigan
Use a swedge cutter on your studs since you got it off then the drums will come of without removing the hub. Some brake shops will/can doit for you.
Re: Tappered Axle 8.75 Brake Drum Removal Tricks? [Re: Crizila] #351206
06/19/09 02:52 PM
06/19/09 02:52 PM
Rio Linda, CA
John_Kunkel Offline
The Erection Connection
John_Kunkel  Offline
Rio Linda, CA
Bad advice, tapers must be assembled dry. The taper contributes to the holding power. (stand by for the "I been doin' it for ___years")
