73 challenger rear tire max size? #350996
06/18/09 12:56 PM
06/18/09 12:56 PM
vashon island washington
hunterstroble Offline OP
I have a 73 challenger with the springs in the stock location and it sits a little higher than normal but not much, it has hemi springs. Right now I have 10" wheels with 4.5" back spacing and a 26x10.5 tire, It's close on the outside lip but it fits. Any way what is the largest tire/ wheel back spacing I can stuff in in there. I have an oppurtunity to get some 295/50/15's on 8" cragar s/s rims, but don't know if they'll fit. any ways thank you very much!
1969 Dodge dart 500 stroker 1973 Dodge Challenger 440
Re: 73 challenger rear tire max size? [Re: hunterstroble] #350997
06/18/09 02:28 PM
06/18/09 02:28 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
With the correct back-space wheel, you may be able to use a 295/50. With a 10" wheel, you will have better results by using a 5.5" back space wheel otherwise you will run into clearance problems with the wheel well outer lip.
Best thing is to measure your rearend and the inner and outer fender well. You will then know for sure what you have to work with.
Re: 73 challenger rear tire max size? [Re: cruzin] #350998
06/19/09 10:58 AM
06/19/09 10:58 AM
Bucks County, PA
500Stroker Offline
500Stroker  Offline
Bucks County, PA
295/50-15, 8" rim, 4.5" back space. 2" over springs.
Re: 73 challenger rear tire max size? [Re: 500Stroker] #350999
06/19/09 01:59 PM
06/19/09 01:59 PM
Thank you guys vey much!
