por-15 question #350353
06/17/09 07:20 PM
06/17/09 07:20 PM
davenport iowa
P
paul69cuda Offline OP
P
davenport iowa
has anyone done this paint the por-15 on let it dry then scuff or sand it. then shoot primer and do base coat clear coat and if you have tell details such as what grit you used on por-15 and did the primer and paint stay on or was it just a waste of time.
Re: por-15 question [Re: paul69cuda] #350354
06/17/09 08:06 PM
06/17/09 08:06 PM
Toledo Ohio area
69fishes Offline
69fishes  Offline
Toledo Ohio area
I have used it several times on the underside of cars; the most recent is a 69 Barracuda which I just finished.
On a previous cars that were done a couple of years ago ir did it as follows:
I brushed the por-15 on the chassis; within 72 hours of por-15 application I sprayed primer; after the primer dried I sanded the primer; then sprayed my basecoat/clearcoat.
It held up very well.
On some 60's GM vehiles they were deliveried with only primer on the undersides of the body. Putting the por-15 on first to protect the body and then the primer for the proper look finish.
Re: por-15 question [Re: paul69cuda] #350355
06/17/09 08:13 PM
06/17/09 08:13 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
I did it in the trunk of my Cuda. Scuffed all areas that were smooth real well then POR15, POR15 primer, then sanded and shot wuth dupont base/clear. Its fine.
How important using the POR15 primer, as opposed to others, I do not know.
Re: por-15 question [Re: paul69cuda] #350356
06/17/09 08:58 PM
06/17/09 08:58 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
Not to start a POR 15 debate, but I learned to stay away from it.
Zero-Rust for me now.
Re: por-15 question [Re: njmopar] #350357
06/17/09 09:14 PM
06/17/09 09:14 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
would you mind explaining why? I always like to hear both sides of the story.
Re: por-15 question [Re: joelson6] #350358
06/17/09 09:53 PM
06/17/09 09:53 PM
NE Ohio
mopar383 Offline
mopar383  Offline
NE Ohio
Me to
81 Dodge Ram My dad bought brand new... my 17 year old sons project
Jeep Wrangler Unlimited .....my wife's baby
Durango....my DD
Caravan...an awesome parts hauler
72 Dart
Re: por-15 question [Re: paul69cuda] #350359
06/18/09 11:00 AM
06/18/09 11:00 AM
davenport iowa
P
P
davenport iowa
thanks i was wondering if anyone had done it. so wetsand or scuff i figure 400 grit dried por-15 then shoot primer and base/clear and this should be fine. this is not a show car but i would like the engine bay to be the same color as the outside.
Re: por-15 question [Re: paul69cuda] #350360
06/18/09 11:59 AM
06/18/09 11:59 AM
Tooele Utah
SamB Offline
SamB  Offline
Tooele Utah
I personally don't care for POR-15.It is a good product but is not user freindly it take to long to dry to go on to the next step.Although if used properly it offers very good protection.Depending on just what you are doing to the car I would recomend using epoxy primer.It is more user freindly.Many restoration shops will say the same thing about the products.
Good Luck Sam
Re: por-15 question [Re: SamB] #350361
06/18/09 12:04 PM
06/18/09 12:04 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Being a resto forum I would say fix it properly. If it was a general forum I would say it's junk.
But, that's just me.
Re: por-15 question [Re: mopar383] #350362
06/18/09 09:31 PM
06/18/09 09:31 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
Me to
I have not had positive long term results with POR15. I prepped exactly as stated, used all their products, but over a period of time (a couple of years) the rust would return. The POR would come off in sheets. I am not the only one with this problem (search old topics on this board). These were on cars that saw real weather after, not show cars. Probably if it never sees moisture, you would be fine. But then what is the point?
It is also just a real pain to apply. Gets all over the place, since it is so thin.
I tried Zero-Rust on a trailer as a test. Did minmal prep as they state and it held up perfect. Been about 5 years now. Way easier to apply, since it is more like regular paint. Way easier to clean up too. POR sticks to everything you dont want it to (better then the rust itself). Like your skin, cloths, etc.
I have done iron furnature, my oil tank and a few other things with Zero Rust and they all look super. The black will fade to a gray, but so does POR.
You could say it was my prep work, but I followed their instructions to the tee with the metal ready, etc. If it is that picky, then it is not worth it for me.
Re: por-15 question [Re: njmopar] #350363
06/19/09 09:47 AM
06/19/09 09:47 AM
South-east Mn
blaze Offline
blaze  Offline
South-east Mn
Where can Zero Rust be purchased?
Re: por-15 question [Re: blaze] #350364
06/19/09 07:56 PM
06/19/09 07:56 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Resto Rick sells it
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: por-15 question [Re: 340SIX] #350365
06/21/09 04:24 PM
06/21/09 04:24 PM
Chicago, IL
Moparman440 Offline
Moparman440  Offline
Chicago, IL
I've had great luck with Zero Rust as well.
