Re: Ideal AFR at wot?
[Re: Dart 340]
#350271
06/17/09 06:32 PM
06/17/09 06:32 PM
The ideal A/F ratio is the one that makes the most power, either on the dyno, or at the drag strip (MPH)...........It can be anywhere from 10.9 to 1 to somewhere in the mid 13's.........and it all boils down to fuel fall out.......How good the fuel distribution of the intake is and how fast the air speed is through the port........
What's your motor build up??? What heads?
[Re: Dart 340]
#350272
06/17/09 08:15 PM
06/17/09 08:15 PM
Posts: 3,078 Edmonton, Alberta, Canada
Dartman75
Since I can change the AFR of my motor on a whim quite easily, I have played a lot with my motor. My motor definitiely starts to choke on more than about 12, and by 10 ti's flat falling on it's face. 13.5 is ideal I thinkhigh twelves to about 13.8.
Other factors play into things that will make it challenge to get WOT perfect across all the RPM ranges. For anythign other than WOT 13.5 to 16 isvery runnable for crusing and very light throttle. I run as lean as 17-18 for long highway stints at cruise, but that's how I get 18MPH from a ~600 horsie motor.
Greg
[Re: Dartman75]
#350273
06/17/09 10:33 PM
06/17/09 10:33 PM
.........but that's how I get 18MPH from a ~600 horsie motor.
Greg
Sorry to hijack......but is that from the small block in your sig pic? If so, have you raced it? If so, what MPH has it run?
#350274
06/17/09 10:33 PM
06/17/09 10:33 PM
Posts: 1,195 Snowing in the north!
Dart 340
moparts member
moparts member
I have a 340 punched .060 over, cylinder pressure is 190 psi cranking, running stock heads, eddy air gap rpm manifold, and eddy performer rpm cam. Carb is a street avenger 670. Running a pertronix ignition but thinking about a msd box.
The car feels light under wot at 13.5-14 but was thinking it might make more power set richer. It does feel more labored running down at 10.5 or so.
[Re: Dart 340]
#350275
06/17/09 10:36 PM
06/17/09 10:36 PM
Off the top of my head, I'd guess the A/F for max power would need to be in the low to high 12 range.........maybe low 13's........but I'd stay a little on the rich side on a pump gas, street car........
#350276
06/17/09 10:46 PM
06/17/09 10:46 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
My dyno sheets say 820hp @7200..700tq@5200 AF 12.98....500 wedge.
The little old lady from Pasadena is back!
[Re: Dart 340]
#350280
06/18/09 07:30 AM
06/18/09 07:30 AM
Posts: 531 Virginia
JimG
Virginia
Thanks guys, all good information.
I am having trouble wrapping my head around why my carb runs perfect 14.5 at 2500 rpms at 5 mph but at 3200 rpm at 702 mph it is running at 12.5 Since I am not loading the motor, should I not still be on the primaries only? and the powervalve should not be open either correct?
I assume you mean 14.5 - 2500 RPM - 55 MPH 12.5 - 3200 RPM - 70 MPH
Does it get progressively worse as you speed up even more? Which primary PV are you running, and what is the vacuum at 2500/55 and 3200/70. You can temporarily, as a test, block the PV with a plug and see if the problem persists.
If it's not the PV, and if it gets progressively worse (or doesn't lean out) as speed/RPM increases further, larger Main Air Bleeds may be in order. Be aware that larger MABs might cause it to run pig rich at very light throttle/load. How's the AFR now at 2-5% throttle at light load?
[Re: JimG]
#350281
06/18/09 10:29 AM
06/18/09 10:29 AM
Dart 340
moparts member
moparts member
I will have to check vacuum and get back to you on that. The primary PV I have is a 5.5 standard not a high flow valve. I run 11 InHg at idle so I thought that would be really close to the right one. I've jetted the carb from the stock 65's to 68's because it was running well into the 16's at 2500 rpm before and now it's right about 14.5
I will get it out on the highway and see if it gets richer, but from memory it doesn't cruising but running wot for extended time get it down into low 11's. I have 68's in the secondaries but didn't want to go smaller yet. Initial wot gives a low 14 for about 2 seconds then she goes to low 11's. Should I wire shut the secondaries and see how it goes? was thinking she would run way lean at higher rpms.
[Re: Dart 340]
#350282
06/18/09 11:11 AM
06/18/09 11:11 AM
Posts: 531 Virginia
JimG
Virginia
OK, that means it's open at vacuum levels below 5.5 in hg (and is richening the mixture), and closed at vacuum levels above 5.5. This assumes the PV is working properly. Put a vacuum gauge in the car and be sure the vacuum doesn't drop below 5.5 at 3200/70 mph when it goes rich. Not likely, but you need to know.
Don't get too hung up on idle vacuum vs. PV rating. You've got a wideband meter - choose the power valve that opens when heavy throttle/heavy load causes the mixture to go lean. You seem to be having the opposire problem, however.
I've jetted the carb from the stock 65's to 68's because it was running well into the 16's at 2500 rpm before and now it's right about 14.5 I will get it out on the highway and see if it gets richer, but from memory it doesn't cruising but running wot for extended time get it down into low 11's. I have 68's in the secondaries but didn't want to go smaller yet. Initial wot gives a low 14 for about 2 seconds then she goes to low 11's.
Forget about the secondaries and WOT AFR for now - save that for last. It's too rich at WOT, and that's good - for now. Rich is safe. If you plan on messing with the primary side, you'll probably make changes that will ultimately upset the WOT readings. Work on getting the primary side right, then when you're sure it's just like you want it, work on the secondary side. To work on the seondary side now is a waste of effort and time.
Only if you think they're popping open at 3200 and causing your rich condition. This must be a vacuum secondary carb, right? Does it have screw in air bleeds or pressed in?
If you're in the 14 neighborhood at 2500, you're halfway home!
#350283
06/18/09 04:05 PM
06/18/09 04:05 PM
Dartman75
Greg
It's the updated flavor of the one in my pic. Slightly out of date pic here: http://www.telusplanet.net/public/zbhansen/temp/DartNewMotorInstalled.JPG It's making 18MPG pure highway leaned right out, city is a whole different ball game mostly due to excessive sitting parked at red lights. The previous build (the one in the current sig pic with the RPM air-gap ran 12.69@109.5MPH at 3600DA, traction limited, and throttle body restricted). I fired my throttle body and traction issues, only to bend a valve resulting in the rebuild for a few extra ponies while I was at it. The sig pic motor was good for about 450 crank, and the new mill I expect around 600 crank. The new updated mill will make it to the track in mid july, once I get on e chassis dyno (July 7th) to make sure the hihger RPM's are tuned correctly before I break something again.
We now return you to your regularily scheduled forum content.
Greg
[Re: Dartman75]
#350284
06/19/09 08:40 AM
06/19/09 08:40 AM
Posts: 902 Mopar Lane,Mississippi
67HEMI
Mine runs the quickest at 12.6 to 12.8.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
