Re: SMR transmissions
[Re: Dabee]
#349520
06/17/09 12:02 PM
06/17/09 12:02 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Yea but does it run! I know some bo hoken with this but it still don't run!
[Re: The Shadow]
#349523
06/17/09 06:25 PM
06/17/09 06:25 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
It would be easiest if you called Pat yourself. He's very easy to talk to.
I agree 100%
Pat is awsome!!! He treated us great with out 45 rfe. He even sent us a new valve body no questions asked. Just ask him, and he will give ya the answers you need. Customer service is great, tranny is great, and eventhough they come out of canada the shipping wasnt that bad at all.
[Re: Moparnut426]
#349525
06/17/09 07:27 PM
06/17/09 07:27 PM
Yeah, Pat will give you lots of answers and send you new parts with no questions. Trouble is, his answers are frequently wrong and... why don't the original parts work?
I had heard good things about Pat (the person, not the products) and then met him at the races. Everything sounded good so I ordered a race trans and converter from him for my Dakota. A year and 3 valve bodies, 2 converters and boxes full of parts later, along with several missed points races, I finally had a trans that would actually get me out of my driveway.
His attitude changes a lot once you get fed up with his BS and get tired of swapping out parts that SHOULD have worked in the first place. Really sad part was he was in my vicinity a couple times for Division/National events and wouldn't come over to my house to see for himself what was wrong. Somehow it all became MY fault!
That the Lord for John Cope who went through the trans and made everything right! My advice is choose John or Rick Allison for your trans and you won't be disappointed.
[Re: DirectConnection]
#349526
06/17/09 08:00 PM
06/17/09 08:00 PM
Posts: 3,078 Edmonton, Alberta, Canada
Dartman75
I believe he's doing GearVendors overdrives so that will give you a rough idea what to expect. I know he was also very big on doing up the 500/518/618 transmissions so that could also be what he's referring to. I have one of Pat's 904's with a GV. The GV in an A-body car is doable but I needed to lower the cross members about 1/2" and hammer another bit of clearance out of the tunnel itself. Other larger car bodies (B,C,E) just require a small dimpling of the trans tunnel.
It's always best to call. Pat is super helpful and definitley one of the original OD tranny builders before they were the cool ticket.
rtxpres, sorry to hear you didn't have a good experience with your tranny. Sometimes there is more to a trans problem than the trans itself. The motor, the car, the build, the parts, bad luck. Everyone can have a bumb product from tiem to time. With that many parts change, it sounds like he tried to make it right. That's a lot more than most vendors and local merchants will do for anyone.
Greg
#349527
06/18/09 09:29 AM
06/18/09 09:29 AM
Dodgem
Ontario, Canada
Thanks for the replies. I was looking at a complete trans and torque converter for 1500 brand new never used. Just wondering how easy is the install. And if anyone is using these overdrive trannys in their cars.
Overdrive transmissions are energy hogs. you will gain a little fuel mileage with the right cam, intake, carb but they really knock off performance.
