bucket seat help Duster #348322
06/15/09 07:59 PM
06/15/09 07:59 PM
ny
DoctorD Offline OP
DoctorD  Offline OP
ny
Had bucket seats in duster out of a barracuda found correct buckets and went to install and mounting holes are different. Car orginally bench seat mounting holes forward to rear same distantance left to right new ones 12&1/2 should I use two outside holes in support brackets and measure in or is there away to detrime location leave for show in two days so any help would be appreciated.
Re: bucket seat help Duster [Re: DoctorD] #348323
06/15/09 08:16 PM
06/15/09 08:16 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Should I use two outside holes in support brackets and measure in?
Yes. I think the two outer L & R bolt holes are constant with either buckets or bench.
Are you using Barracuda or Duster bucket seat tracks?
Re: bucket seat help Duster [Re: In_The_Pink] #348324
06/15/09 08:21 PM
06/15/09 08:21 PM
ny
DoctorD Offline OP
DoctorD  Offline OP
ny
Should be duster I know seat backs and covers were from 71 Duster. Thanks
Re: bucket seat help Duster [Re: DoctorD] #348325
06/16/09 12:19 AM
06/16/09 12:19 AM
The Dalles, OR.
Dusted_Ya Offline
Dusted_Ya  Offline
The Dalles, OR.
Just redrill the 2 inner holes (If I remember correctly)
Re: bucket seat help Duster [Re: DoctorD] #348326
06/16/09 12:13 PM
06/16/09 12:13 PM
wv
Dartcuda Offline
Dartcuda  Offline
wv
You need to drill 4 new holes per seat , the bench seat holes are not used . The floor pan should be dimpled where the holes go . Also don't forget to add the reinforcment plates to the inner holes.
