When they inflate tires..................... #348086
06/15/09 05:33 PM
06/15/09 05:33 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
do they use some special air in the compressor or a chemical for sealing?
My old man was telling me this as I noticed all my tires on the 69 went from 32 down to 27.5....he laughs as his GMC van has held 34psi on all 4 tires for 6 years
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: When they inflate tires..................... [Re: Pyper70] #348087
06/15/09 05:43 PM
06/15/09 05:43 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Nothing but compressed air. Loss of air has to do with the outdside temp and porosity of the tire rubber as well as the seal to the rim.
Re: When they inflate tires..................... [Re: Pyper70] #348088
06/15/09 05:43 PM
06/15/09 05:43 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Yeah its cal t'ar ayre. You just don't have to change yer air as often. Yer dad, OTH is waaaay over due
Seriously, tires should seal on the rim with nothing but the lube (soapy water) they use to mount them. If they leak, there's either a bad valve stem, bent or gouged rim, or a hole in the tire (or dry cracked) or a combination of all of the above.
Re: When they inflate tires..................... [Re: Scott Carl] #348089
06/15/09 05:47 PM
06/15/09 05:47 PM
scratchnfotraction Offline
an inner tube
nitrogine maybe
compressed air
gas co2 out of the fix a flat with sealent from a can
Re: When they inflate tires..................... [Re: scratchnfotraction] #348090
06/15/09 05:57 PM
06/15/09 05:57 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
A lot of the tire shops are going to a nitrogen fill rather than compressed air. The theory is that nitrogen does not expand and contract with temp changes like compressed air does. For example blow up a balloon, tie it and put it in the freezer. Take it out an hour later and see that it has shrunk. Leave it out in the sun and it will expand. Supposedly nitrogen will not shrink or expand. I am not a chemist, just relaying what I have been told. Green valve stem caps indicate nitrogen filled tires. It is also compatible with normal compressed air.
Re: When they inflate tires..................... [Re: Pyper70] #348091
06/15/09 06:30 PM
06/15/09 06:30 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Get some respect.
Re: When they inflate tires..................... [Re: MoparforLife] #348092
06/15/09 06:37 PM
06/15/09 06:37 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Nitrogen molecules are larger than air molecules,,, hench less leakage
I am truckless..
Re: When they inflate tires..................... [Re: 340SHORTY] #348093
06/15/09 06:54 PM
06/15/09 06:54 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
The use of nitrogen in passenger car tires is nothing but a sleazy cash grab by the retailers.
Did you use a different gauge both times you checked the pressures? Were the tires at the same temperatures both times?
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: When they inflate tires..................... [Re: DPelletier] #348094
06/15/09 08:02 PM
06/15/09 08:02 PM
alberta
Publicbottle Offline
alberta
Its true that nitrogen has more resistance to temp changes, there is just not as much compared to regular compressed air which happens to be full of moisture, which is why your air pressure in your car tires would flucuate depending on outside air temp or seasons. In aviation we use dry nitrogen, but I still see effect of temps on tire pressures...just not as dramatic. For example an aircraft tire will be filled to 150psi at room temp. after a couple landings the brakes while heat up that area and the tire pressure will increase to around 160psi due to the increased temp of the friction braking.
Re: When they inflate tires..................... [Re: Publicbottle] #348095
06/15/09 08:19 PM
06/15/09 08:19 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
and that there nightrogen will clean yer engeen too, I saar it on TV!
The fact that nitrogen is a large part of air means the returns are less to do with moisture and stability ( the other gasses change more easily to temperature) than to the fact some people have to have what the racers have and there are others willing to sell it to them and advertise it to the masses to cover the costs and generate a profit.
Every time I see another grimy set of wheels with those caps, I recognise that there is one more person that doesn't check their tire pressures, but is willing to spend a bit more to keep it stable...
Re: When they inflate tires..................... [Re: DPelletier] #348096
06/15/09 10:24 PM
06/15/09 10:24 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
I must be one of those sleazy cash grab tire retailers because I sell it and install FREE on all tires I sell! Been using it for over 4 or 5 years now, have had great luck. Nitrogen will keep your tires running cooler (longer life), keeps moisture away, less corrisoin between rim and tire bead, less rim leaks (if you have had a Chrysler with chrome rims you know what I mean) and yes air pressure doesn't change as much, It won't stop the air from leaking' but with the larger moducles it slow its down and without the moisture it doesn't change as much. Again I'm only a sleazy cash grab tire dealer, so what do I know after 35+ years in the business
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
Re: When they inflate tires..................... [Re: Pyper70] #348097
06/15/09 10:32 PM
06/15/09 10:32 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
to anwser your ?, different tire companies have different bead sizes, so if you have a tire that has a loose fitting bead on a rim that is also a loose fitting rim you will lose more psi as compared to a tight fitting rim and tire. Chrome rims also are know to leak down faster. And no there is nothing that we use except mounting lube. I hope this helps
Re: When they inflate tires..................... [Re: deansrr] #348098
06/15/09 10:50 PM
06/15/09 10:50 PM
Can you provide anything to back that up?
It doesn't keep moisture AWAY, it's just that hopefully there's less moisture in the N2 to begin with. Since there's much less O2, rust/corrosion is slowed way down.
I'm pretty sure the reason for this is the fact that there's not much moisture in N2 Atmosphere is largely N2, anyhow, and I can't imagine that the difference in delta T change for N2 and O2 is very much.
You PROBABLY could accompomplish the same thing with CO2, and except for inhibiting rust/ corrosion, you could probably use dried air the point being that there's nothing really magic about N2
Re: When they inflate tires..................... #348099
06/15/09 10:57 PM
06/15/09 10:57 PM
I'd air em up in your shop rather than at a station as I cant believe the amt of water I see spewing out of the air chucks at most of those places
Re: When they inflate tires..................... #348100
06/15/09 11:16 PM
06/15/09 11:16 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
nitrogen is pretty much dry air, that is what I meant by keeping the moisture out, without the humity of moist air your tirs will run cooler thus extending the life of your tires.
Re: When they inflate tires..................... [Re: deansrr] #348101
06/16/09 12:12 AM
06/16/09 12:12 AM
Montana
P
Posest Offline
Posest  Offline
P
Montana
I have those green caps on my grimy wheels. Sad thing is that I do check my tire pressure. Stays around 40 psi on my Toyota beater. I have more rust than solid panels. I am a firm believer in good tires and keeping the right tire pressure. I have yet to pay for nitrogen in any tire inflated with it. Seems that even in college they are teaching the positive effects of using nitrogen in tires.
Re: When they inflate tires..................... [Re: stumpy] #348102
06/16/09 02:19 AM
06/16/09 02:19 AM
Ohio
john55 Offline
john55  Offline
Ohio
the air we breathe is almost 80% nitrogen
The Plymouth Win You Over Beat Goes On
Re: When they inflate tires..................... [Re: deansrr] #348103
06/16/09 12:54 PM
06/16/09 12:54 PM
DPelletier Offline
DPelletier  Offline
If you're providing it for free, then you're not sleazy! It's STILL a waste of time, though.
For airplanes that see SEVERE fluctuations in altitude, temperatures, speed and impacts; sure. For passenger car tires ITS A WASTE OF TIME.
Tire temperature is a function of load, deformation and pressure. I seriously doubt tires running nitrogen at the same pressure as air run measureably cooler in a passenger car application.
Moisture in compressed air is a problem that can and should be addressed with an appropriate air dryer and again, nitrogen isn't needed for that either.
Sorry, but most soccer moms are being sold a bill of goods based on some accurate science that makes little to no difference in the real world and they're being charged an extra $5.00 a tire for it usually.
my 2 pennies, again.
Re: When they inflate tires..................... [Re: DPelletier] #348104
06/16/09 05:05 PM
06/16/09 05:05 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
I have seen it help, what are you basing your facts on? do you work in this field and know what is really going on?
Re: When they inflate tires..................... [Re: deansrr] #348105
06/16/09 05:40 PM
06/16/09 05:40 PM
D and I both worked in the HVAC field, and although I'm not to the point of engineering, I think he and I both have a pretty good idea of the thermodynamics of gases.
The idea that a drop or two of moisture in a tire can make some magic measurable degree (no pun) of difference in temperature is ridiculous. I WILL agree that dry air might help prevent rust/ corrosion of rims, but that's about it.
The difference in molecule size between O2 and N2 that would make the arguement of "preventing leakage" is again off the mark.
www.getnitrogen.org/pdf/graham.pdf
The other obvious question we all have to ask nowadays is "is this green?"
So let's add up the tremendous amount of energy it takes to extract Nitrogen from wherever you are going to get it, IE liquify air, all the energy it must take to filter purify, etc, and the transportation of VERY heavy bottles and storage containers as opposed to....
just running a compressor and possibly an air dryer/ filter
