Thermostat or no thermostat ? #347925
06/15/09 04:12 PM
06/15/09 04:12 PM
Motown, Mi
P
PAULS_340 Offline OP
P
Motown, Mi
Is there an advantage to not using a thermostat? I don't need the heater. My '71 340 ran perfect without a thermostat at last weeks HotRod Power Tour ? Can I cause any damage? thanks in advance.
Still looking for LM29H1B415501, '71 Demon 340
Re: Thermostat or no thermostat ? [Re: PAULS_340] #347926
06/15/09 04:30 PM
06/15/09 04:30 PM
Az
Crizila Offline
Crizila  Offline
Az
You should run a thermostat on the street. Normally, engines run best at a specific temp ( usually 180 to 200 ). Running on ether side of that range can cause multitides of issues, and none positive. Running a stat will get you in to that most efficient operating range as quickly as possible and help keep you there. Running without a stat will not cause immediate damage - un less you go in to major over-heat ( which can happen ).
Fastest 300
Re: Thermostat or no thermostat ? [Re: PAULS_340] #347927
06/15/09 05:00 PM
06/15/09 05:00 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Running no stat, the water passes throw the radiator too fast, not disapating/exchanging heat transfer,.....so you could actualy run hotter,....or in some extreme cases you could run too cool, which isn't good for oil viscosity to properly lubricate and flow through out the engine,....if you feel you must run without a stat, there are "restrictor washers" avaliable, which basically look like a washer, you'll need to experiment with various sized orifices to acheive the desired running temp,....which should be around 190 degress IMHO,....if coolant flow/thermostat opening is a concern, drill a relief hole in the stats base before you install it, 1/16 up to 1/8, max 1/4" dia
Re: Thermostat or no thermostat ? [Re: PAULS_340] #347928
06/15/09 06:45 PM
06/15/09 06:45 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
You always want to try to get the motor warmed up quickly with as little load as posibble. Motors wear the most when cold. A thermostat will get the motor up to running temp as quickly as possible
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Thermostat or no thermostat ? [Re: HealthServices] #347929
06/15/09 06:52 PM
06/15/09 06:52 PM
Central ILL.
twister6 Offline
twister6  Offline
Central ILL.
I agree
2003 Ram3500 Quad4x4 2000 Dodge Avenger 72 Duster 68 Dart GT
Re: Thermostat or no thermostat ? [Re: DAYCLONA] #347930
06/15/09 07:04 PM
06/15/09 07:04 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
I don't believe people still believe this old wives tale.
Re: Thermostat or no thermostat ? [Re: JonC] #347931
06/15/09 07:43 PM
06/15/09 07:43 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yes I can't believe how many people say that. In my 35 years in the auto service field I have never had a car run hotter without a stat. Ron
Re: Thermostat or no thermostat ? [Re: JonC] #347932
06/15/09 07:45 PM
06/15/09 07:45 PM
El Cerrito, by San Francisco
last426 Offline
last426  Offline
I used to post and post about how this is not true. I finally gave up. The only way it could possibly be true is if without the stat it created cavitation sufficient to slow everything down. I don't think so. Kim
Re: Thermostat or no thermostat ? [Re: DAYCLONA] #347933
06/15/09 08:06 PM
06/15/09 08:06 PM
Az
Crizila Offline
Crizila  Offline
Az
Fastest 300
Re: Thermostat or no thermostat ? [Re: last426] #347934
06/15/09 09:33 PM
06/15/09 09:33 PM
Ohio
racerAL Offline
racerAL  Offline
Ohio
....no stat here...and no overheating ..or cooling problems either...car idles for 7-10 minutes it might get up to 190 or so,..waiting in staging lanes on a 90 degree day.still no issue..it's never been over 225 even after hot lapping on hot humid day...i run a typical elec. water pump drive and use a cooling fan module out of a honda accord...
-1967 Plymouth Satellite #3555
446 cid on E-85
best 1/4 et 10.577 @ 127.58
best 1/8 et 6.722 @ 100.68
best 60ft. 1.419
Re: Thermostat or no thermostat ? [Re: racerAL] #347935
06/15/09 09:41 PM
06/15/09 09:41 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Lot of difference between a race car and a street car.
Re: Thermostat or no thermostat ? [Re: stumpy] #347936
06/15/09 09:55 PM
06/15/09 09:55 PM
Ohio
racerAL Offline
racerAL  Offline
Ohio
.....your absolutely right, i was responding more to the wives tale about not running a stat and got caught up in that and didn't think about the original post..soooo my is that if he just ran the power tour withOUT a stat,and had no problems,i would say that a stat is not needed on a street car during the warmer months were heating up engine isn't so crucial...
446 cid on E-85
best 60ft. 1.419
Re: Thermostat or no thermostat ? [Re: racerAL] #347937
06/15/09 09:57 PM
06/15/09 09:57 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I don't like going without a stat because of the increased wear when an engine runs cold all the time.
Re: Thermostat or no thermostat ? [Re: stumpy] #347938
06/16/09 01:51 AM
06/16/09 01:51 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run a 160 stat in my 63 and it works good. Car runs about 170 while driving even on a hot day. In traffic at idle it will creep up to 190 if I sit for a good bit idleing. I drive it alot and I just use a stock water pump with a factory fan blade. No electric fan. Ron
