trans problem 95 Ram 1500 #347910
06/15/09 03:22 PM
06/15/09 03:22 PM
Manheim PA.
mopardad Offline OP
mopardad  Offline OP
Manheim PA.
Need help figuring out a problem with the trans in my 95 Dodge Ram, its a 500 or 518 or whatever the overdrive 727 style trans is, problem is it just quit like its in neutral, had to come home on a rollback, unloaded the truck left it sit for a few hours backed down my driveway put it in drive hammered it with the brakes on & it held fine, did this a few times on held it for a long time it would not slip or anything, where do I start looking for the problem, relief valve ? originally I thought that it was low on trans fluid because the dipstick tube oring leaks but I put some in it when it would not drive & it still acted the same.
Any thoughts
Re: trans problem 95 Ram 1500 [Re: mopardad] #347911
06/15/09 04:40 PM
06/15/09 04:40 PM
Waterloo Iowa
8
80mirada Offline
80mirada  Offline
Waterloo Iowa
Might be the drainback valve in the cooler lines, they have killed more 518s than anything else
Re: trans problem 95 Ram 1500 [Re: mopardad] #347912
06/15/09 07:57 PM
06/15/09 07:57 PM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
Remove the pan and see how much metal is in there plugging up the filter!
Re: trans problem 95 Ram 1500 [Re: 80mirada] #347913
06/15/09 08:06 PM
06/15/09 08:06 PM
Manheim PA.
mopardad Offline OP
mopardad  Offline OP
Manheim PA.
Doubt if its junk in the filter, fluid looks fresh & no sparkly stuff
Tell me about the drainback valve, is it part of the cooler lines
