Well it's time to replace my 50 year old copper radiator. I'd like to install an aluminum radiator to save weight and cool the motor easier. I'm having trouble finding something that fits this Frankenstien. Most of the radiators I've looked at that will fit don't have a trans cooler. I'm running a REAL loose 8" TA converter, will an aftermarket aircooled trans cooler be enough? I do more street driving that strip, will it work 200 miles at a crack. I've been using a add on trans cooler along with the water cooled unit. Dave
