Page 1 of 3 1 2 3
Convertor bolts with lock tight? #346199
06/14/09 12:29 AM
06/14/09 12:29 AM
fullmetaljacket Offline OP
Are you guys using thread locker on your convertor to flexplate bolts?
Re: Convertor bolts with lock tight? [Re: fullmetaljacket] #346200
06/14/09 12:34 AM
06/14/09 12:34 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
yes
Tony
70 AARCuda Vitamin C
Re: Convertor bolts with lock tight? [Re: fullmetaljacket] #346201
06/14/09 12:35 AM
06/14/09 12:35 AM
Pennsylvania
proshiftcharger Offline
Pennsylvania
yes and check them periodically too.
Re: Convertor bolts with lock tight? [Re: fullmetaljacket] #346202
06/14/09 05:53 AM
06/14/09 05:53 AM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
That is (removeable thread locker) so you can
get the bolts out some day.
They do make a thread locker that takes a torch
to undo them. Watch what you buy.
Snap your neck, mega G-force launch, is all I want!
Re: Convertor bolts with lock tight? [Re: BDS871Cuda] #346203
06/14/09 07:39 AM
06/14/09 07:39 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Blue locktite is what you want.Rocky
Chrysler Firepower
Re: Convertor bolts with lock tight? [Re: therocks] #346204
06/14/09 08:53 AM
06/14/09 08:53 AM
negative on that.
RED is the only thing to use on converter
bolts, once you have one back out, you'll never use anything else.after ytou bsnug up make sure some is holding the front crank bolt 1-1/8 and tighten more, i use a hammer on the wrench to keep them snugged very tight.
just ask ACTIONANGE.
Re: Convertor bolts with lock tight? [Re: therocks] #346205
06/14/09 08:54 AM
06/14/09 08:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I use the red locktite and I can get my impact on them
(in the starter area without the starter in) and get
them good and tight. Same thing when I take them out
Re: Convertor bolts with lock tight? [Re: MR_P_BODY] #346206
06/14/09 09:00 AM
06/14/09 09:00 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
i use the blue without issue. if i used red i would never get them back out. before i started using thread locker, the bolts would contantly loosen.
Re: Convertor bolts with lock tight? [Re: mopar dave] #346207
06/14/09 09:09 AM
06/14/09 09:09 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I use red and tighten to 30 Ft Lbs. Haven't had one come loose since I started doing it this way.
Re: Convertor bolts with lock tight? [Re: WILD BILL] #346208
06/14/09 09:14 AM
06/14/09 09:14 AM
Q
Quicktree Offline
Quicktree  Offline
Q
I have always used blue. never had one back out.
Re: Convertor bolts with lock tight? [Re: WILD BILL] #346209
06/14/09 09:18 AM
06/14/09 09:18 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've used both. Red is diffucult to remove. A few thoughts. The torque applied with a impact gun to a 3/8" bolt would probably be excessive. Why don't converter bolts come loose on a high milage street car without locktite? I locktite mine and have over torqued them also. Just wondering why they tend to come loose in a drag racing application.
Doug
Re: Convertor bolts with lock tight? [Re: dvw] #346210
06/14/09 09:27 AM
06/14/09 09:27 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Doug
I dont use the full power of the impact, just a couple
of short hits... i would guess 40 ft lbs. All the
converter bolts I've seen come with locktite(blue)
on them. In racing we put all the fasteners in
greater stress than any streetcar.
With the red locktite the impact pops them free real
easy(the shock breaks the bond)
Re: Convertor bolts with lock tight? [Re: MR_P_BODY] #346211
06/14/09 10:07 AM
06/14/09 10:07 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
I don't know where people got the idea that a bolt with red Loctite would "never come loose". Maybe it's material for a future Mythbuster episode. They always come out, sometimes if they are a little stubborn, all it takes is a little heat(nothing exotic-I just use a mini torch at the shop) and they back right out.
Always use red loctite on TC bolts. Actually, it's a good idea to loctite just about everything on a drag car. Bolts like starter bolts, trans to bell bolts, motor mounts, pulleys, driveshafts etc, etc. Many guys are still using 40 year old blocks and trans cases and the threased holes have been compromised over the years. One would be surprised at how many bolts are loctited by the factory on your daily driver. The reason for going overboard on a race car is the parts are under stress constantly and the violent shock of launching the car can lead to fastener loosening and subsequent component failure.
MB
Re: Convertor bolts with lock tight? [Re: HPMike] #346212
06/14/09 10:18 AM
06/14/09 10:18 AM
MS
redex79 Offline
redex79  Offline
MS
Truckin Weekend !
70 Dodge Dart Swinger
11 Ram 1500 Laramie 4x4
21 Dodge Durango GT
Re: Convertor bolts with lock tight? [Re: redex79] #346213
06/14/09 10:29 AM
06/14/09 10:29 AM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
red and my convertor bolts are 7/16
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: Convertor bolts with lock tight? [Re: MR_P_BODY] #346214
06/14/09 10:41 AM
06/14/09 10:41 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I do the same thing and start pulling the trans out of some of these newer cars and you will be surprised at what has lock tight on it.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Convertor bolts with lock tight? [Re: dusturbd340W5] #346215
06/14/09 10:51 AM
06/14/09 10:51 AM
Okay, Okay! I'm using the RED and the BLUE at the same time so that every body is happy. How's that? LOL
Thanks a lot guys. I've used Locltite before on them, but just forgot which one with all the stuff I have in mind these days.
Re: Convertor bolts with lock tight? [Re: dusturbd340W5] #346216
06/14/09 11:03 AM
06/14/09 11:03 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
We use red loc tite on everything on diesels, never had any problems pullin the bolts with a long wrench and a bump with the palm, I use the blue on stuff like toilet seats and fords Oops, only kiddin, We dont use anything on fords
Re: Convertor bolts with lock tight? [Re: emarine01] #346217
06/14/09 11:14 AM
06/14/09 11:14 AM
colorado
chargermop Offline
chargermop  Offline
colorado
go red
Re: Convertor bolts with lock tight? [Re: emarine01] #346218
06/14/09 11:24 AM
06/14/09 11:24 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Aren't those the same things
Page 1 of 3 1 2 3
