85 Diplomat with A/C, won't shut off the heat... #345480
06/12/09 11:37 PM
06/12/09 11:37 PM
Fort DODGE, Ioway
O
origcharger Offline OP
O
Fort DODGE, Ioway
Has A/C with automatic temperature control, have to clamp off a heater hose to shut off the heat
Under what circumstances is that vacuum operated valve supposed to close? Or is it a flapper door/control problem.
MOPARTS ALERT!: Chris Pugh aka gabodyman of Dalton, Georgia, cashed my $140 money order on 4-16-02 never sent parts. On 3-19-07 he agreed to return my money; "april 9, it will be in the mail by that date""will do as promised. chris" Still no parts and no money!
Re: 85 Diplomat with A/C, won't shut off the heat... [Re: origcharger] #345481
06/12/09 11:53 PM
06/12/09 11:53 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
My money is on a flapper door. If the setup is like F-bodies (and I think it is), all incoming air goes through the A/C evaporator first, then either through the heater core or bypasses the heater core.
Better look under the dash and check those vacuum lines.
Re: 85 Diplomat with A/C, won't shut off the heat... [Re: In_The_Pink] #345482
06/13/09 09:51 AM
06/13/09 09:51 AM
Fortworth TX
mod5v Offline
mod5v  Offline
Fortworth TX
If its like my 84 d150 it only shuts the valve in the heater hose on Max A/C and "OFF". other wise it lets hot water pass. I determined this by putting a vacuum gauge on the line that connects to the valve and running it in all positions.
Re: 85 Diplomat with A/C, won't shut off the heat... [Re: mod5v] #345483
06/13/09 10:46 AM
06/13/09 10:46 AM
Montana
FuryUs Offline
FuryUs  Offline
Montana
Wife's Durango is the same way--I added a ball valve to the heater hose and turn it off in the summer to get NO HEAT.
Re: 85 Diplomat with A/C, won't shut off the heat... [Re: mod5v] #345484
06/13/09 09:21 PM
06/13/09 09:21 PM
Crowley,TX
70Duster360 Offline
super street
70Duster360  Offline
super street
Crowley,TX
mod5v is correct. The water valve only closes on max A/C. If you have heat all the time, then the servo motor for the blend air door is bad. I replaced quite a few of these in my days at the C/P house. I converted my old 5th Ave to a cable from an old (late 70s'?) LeBaron from the wrecking yard. Cost almost nothing compared to a new servo, which was more than the 5th was worth . Hope this helps!
Re: 85 Diplomat with A/C, won't shut off the heat... [Re: 70Duster360] #345485
06/15/09 07:38 AM
06/15/09 07:38 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
these cars also have a vaccuum fitting behind the controls that is prone to crumbling after 20 years....might be the culprit, too. of course, if that's the case, it should also default to just floor heat/cool
2017 Grand Cherokee Overland
