Ignition switch? Car only stays running if I hold key #345104
06/12/09 05:27 PM
06/12/09 05:27 PM
PA
KGorney Offline OP
KGorney  Offline OP
PA
When I start my Duster, it fires then dies. I found however, that if I start it, then back the key off just a hair it will stay running, then when I let go of the key and it returns to the normal run position it dies again. Is this a sure fire indication that the ignition switch is gone, or could it still be something downstream?
Re: Ignition switch? Car only stays running if I hold key [Re: KGorney] #345105
06/12/09 05:39 PM
06/12/09 05:39 PM
IMGTX Offline
IMGTX  Offline
Check the ballast resister under the hood first.
They go bad often and give you that symptom.
Re: Ignition switch? Car only stays running if I hold k [Re: IMGTX] #345106
06/12/09 05:41 PM
06/12/09 05:41 PM
PA
KGorney Offline OP
KGorney  Offline OP
PA
I forgot to mention I tried replacing the ballast resistor and it still had the same issue. I had to hot wire a line from the coil positive to the battery positive to keep it running to get it home.
Re: Ignition switch? Car only stays running if I hold k [Re: KGorney] #345107
06/12/09 05:51 PM
06/12/09 05:51 PM
IMGTX Offline
IMGTX  Offline
OK that could be the switch or the wiring at the bulkhead connector.
1st check both sides of the ballast resister with a VOM and the key on. Even new ones can be bad.
2nd check the connectors under the dash for voltage with the key on. Does the radio/turnsignals/etc work when in the run position?
3rd If you have voltage at the switch check both sides of the bulkhead connector.
Here is a link to wiring diagrams that may help you trace the wires.
http://www.mymopar.com/index.php?pid=28
Re: Ignition switch? Car only stays running if I hold k [Re: IMGTX] #345108
06/12/09 05:56 PM
06/12/09 05:56 PM
PA
KGorney Offline OP
KGorney  Offline OP
PA
Thanks for the link! I'll start tracing.
There is power to the lights and radio in the run position.
Re: Ignition switch? Car only stays running if I hold k [Re: KGorney] #345109
06/12/09 05:59 PM
06/12/09 05:59 PM
IMGTX Offline
IMGTX  Offline
I'm thinking bad ballast or bad bulkhead connector myself.
Good Luck
Re: Ignition switch? Car only stays running if I hold key [Re: KGorney] #345110
06/12/09 06:49 PM
06/12/09 06:49 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Bulkhead connector or wiring, I would suspect. Those ign switches rarely fail.
Re: Ignition switch? Car only stays running if I hold key [Re: KGorney] #345111
06/12/09 07:52 PM
06/12/09 07:52 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
EZ to test with either a 12V test lite or voltmeter.
Turn the key to the run position and check if there is 12V @ the ballast resistor.
If not...
Then start checking backward..
Ballast resistor > bulkhead connector >ignition switch.
Just my $0.025..
Re: Ignition switch? Car only stays running if I hold key [Re: Sinitro] #345112
06/13/09 01:07 PM
06/13/09 01:07 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
if you don't have BRAKE AND OIL ( if oil is not a gauge )on cluster at RUN position, then ign switch is bad.
If you never loose those lights, then problem is on bulkhead or blue wire up to ballast ( including ballast itself )
note, is normal those lights dimming while cranking since ballast is retro feeding the cluster on cranking moment, not ign switch
Re: Ignition switch? Car only stays running if I hold key [Re: NachoRT74] #345113
06/13/09 01:45 PM
06/13/09 01:45 PM
I can't believe this question got posted as I am having the EXACT same issue with my Challenger right now. I just replaced the ignition switch due to it loosing the dash lights, etc, but it still won't run unless I hold the key just off the start position. The dash lights/clock are working again also. I have already went the ballast resistor route. Thinking by some of the comments here it may be the bulkhead connector. If I find it I'll post out my results so someone else might be able to save some time/money.
Re: Ignition switch? Car only stays running if I hold key #345114
06/13/09 04:25 PM
06/13/09 04:25 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Lightning net is not feeded by Ign switch, comes directly from batt/alt wiring. So ANY LIGHT issue will never come from Ign switch
Re: Ignition switch? Car only stays running if I hold key [Re: NachoRT74] #345115
06/13/09 04:31 PM
06/13/09 04:31 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
EDITING!!!
- IF YOU LOOSE THOSE CLUSTER INDICATORS when cranking, PROBLEM IS DEFINITELLY on bulkhead. They should simply dim, but never get lost.
-Being engine is starting, the ballast is good, because power is getting brown wire and then is feeding the blue wire what feeds the Ign Module on engine harness THROUGHT ballast.
- If you loose the cluster indicators on RUN, problem is on Ign switch or some fuse what feeds cluster indicators ( on some models ). Hopwver of course fuse doesn't have something to do with ign itself, just a cluster portection. Of course fuse blown will keep indicators off on any ign position.
Re: Ignition switch? Car only stays running if I hold key [Re: NachoRT74] #345116
06/13/09 05:44 PM
06/13/09 05:44 PM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Every single time this has happened to me it was the ecu. Every time. The first three times I chased switches, ballasts, and wiring. I always carry a cheap back up box now. Disregard if you're not running the electric ignition.
I can't afford this. mark
Re: Ignition switch? Car only stays running if I hold key [Re: a12superbee] #345117
06/13/09 06:42 PM
06/13/09 06:42 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
Yep! Just like the 'old' days. I carry a spare ECU, cap & rotor, ign coil and a ballast. And I have had to use several of them from time to time.
Re: Ignition switch? Car only stays running if I hold k [Re: Classof70Chally] #345118
06/13/09 08:15 PM
06/13/09 08:15 PM
PA
KGorney Offline OP
KGorney  Offline OP
PA
I had tried the ballast resistor, ECU and coil, since I too, always carry an extra.
I ran tests all over with a 12 volt light and it turned out the bulkhead harness connector was slightly loose and corroded on the blades inside. I cleaned the contacts, connected the harness fully and locked it in place, then the car ran fine. Took it out for spin, turned it off and started it a few times and all seems fine.
Re: Ignition switch? Car only stays running if I hold k [Re: KGorney] #345119
06/14/09 03:05 AM
06/14/09 03:05 AM
That's cool you found it. I'm going to look at mine later today and hopefully it is just a connection. I also have the extra ECU, ballast in the glovebox too, lol.
Re: Ignition switch? Car only stays running if I hold k #345120
06/15/09 01:26 AM
06/15/09 01:26 AM
Found my problem. The blue wire from the bulkhead connector to the ballast resistor had no voltage. I pulled the connector and found the terminal slightly burned. This harness came from Evans wiring and they crimped the terminal over the insulation and it wasn't making a good connection. Due to the poor connection it drew more amperage and melted the insulation at the terminal. I pulled the terminal out, cleaned it up, recrimped the wire and soldered the terminal/wire. She fired right up and stayed running.
Re: Ignition switch? Car only stays running if I hold k #345121
06/15/09 02:50 AM
06/15/09 02:50 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
wish i woulda saw this earlier for ya. had/have the same problem w/ my car occasionally. took dash in and out a couple times, switched ignition switches and tons of stuff. then i checked it and was like doh!
Re: Ignition switch? Car only stays running if I hold k [Re: KGorney] #345122
06/15/09 08:57 AM
06/15/09 08:57 AM
IMGTX Offline
IMGTX  Offline
FYI
If you ever want to replace the terminals NAPA sells them. They are listed as a GM part but are EXACTLY the same as the factory mopar ones.
Re: Ignition switch? Car only stays running if I hold k [Re: IMGTX] #345123
06/15/09 03:18 PM
06/15/09 03:18 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
does anybody know the size wire that goes from the ignition to the block? i'm just going to replace the whole thing. and you say you can get the terminal from napa, are you talking about the one coming from the inside or the outside, or both. thanks a bunch. going on a 180-200 mile trip to a car show this weekend and dont want this problem.
