Re: what size stall for my 440?
[Re: Racerwill1]
#345063
06/12/09 05:52 PM
06/12/09 05:52 PM
Posts: 120 Arizona
anmracing
Arizona
What size stall would be good for my 440? Its in a 74 challenger. 906 heads, .509 purple shaft, 750 holley. It's not for the track, just driving on the weekends and around town. Thanks
With that combo I would say go with 3000 RPM stall.
[Re: anmracing]
#345065
06/12/09 06:31 PM
06/12/09 06:31 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
3000 stall and install the cam at 102 to 104
[Re: dwbiggs]
#345068
06/12/09 08:01 PM
06/12/09 08:01 PM
Posts: 2,179 S.E. Conn
Hoof Hearted
S.E. Conn
Quote: "For God's sakes don't skimp on the converter...get a quality one...you won't regret it."
umm. I'm running a 3800lb 69 B-body with a 496 stroker, beefed up 727 rev. manual valve body with external cooler, 3:23's, M/T drag radials that hook real nice and running high 11's...
This combo also includes a very cheapo Mopar Performance "Economy Hi-stall" 2200rpm (factory 340 hi-stall?) converter bought for $240 new 3 years ago and performs great.
2005 300C Hemi 2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
[Re: Hoof Hearted]
#345069
06/12/09 11:11 PM
06/12/09 11:11 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
What cam and what size rear tires are you running ?? Ron
[Re: Hoof Hearted]
#345070
06/13/09 05:38 AM
06/13/09 05:38 AM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
I thought I said 2200-2400? I guess Hoof is the only one to understand. Wasn't this just a street car. I would of picked a smaller cam, but the 509 will work. On the street it doesn't matter what stall you have (with in reason) or what the gears are because it never hooks.
Yes the bigger stall is better at the track, but it sucks for freeway cruisen when matched up with low gears.
Snap your neck, mega G-force launch, is all I want!
[Re: BDS871Cuda]
#345071
06/13/09 02:33 PM
06/13/09 02:33 PM
Posts: 1,460 oklahoma
forphorty
oklahoma
hoof has a 496, the original poster has a 440. i do agree with you somewhat in that with typical hard street tires it might not hook up anyway no matter what convertor. But he might get the urge to go racing someday and that 509 will be a dog out of the hole with a 2400 stall. I agree that if it is just a street cruiser he ought to just put a smaller cam in it, about 230 at .050 or thereabouts, along with your recommended 2400 convertor . As far as Roofs cheapo MP convertor, i've got one behind a mild 400 and like it but i might be a bit leery of running one with a high output motor for fear it might not last long.
[Re: anmracing]
#345073
06/13/09 08:49 PM
06/13/09 08:49 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
for a street car, I agree...
More would be ideal, but a 440 is pretty forgiving with anything 3K or more.
[Re: Racerwill1]
#345075
06/14/09 01:11 AM
06/14/09 01:11 AM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
Ran the .509 for years....and I can tell you that there is NO way a 2400 rpm convertor is a choice at all!! 3000 - 3400 is what you need. And if you're worried about not being able to "cruise" you're worrying too much!!! My Challenger was a tad "loose" under 40 MPH with a 3800 B&M Holeshot, but on the highway it was no problem. No difference in mileage to speak of. Don't waste the time with a low stall convertor...get one that will make use of the cam. That .509 is a great cam.
