Hemi pistons in 318 ? #344798
06/12/09 12:11 PM
06/12/09 12:11 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
If I put some Hemi pistons in my 318 then what would be a nice tight clearance to shoot for? I don't want them sloppy loose in there, but don't want it freezing up either. This is a 4 inch stroker motor I am thinking of slapping together for
Oh yeah they are 5.7 hemi pistons and rods
Re: Hemi pistons in 318 ? [Re: HotRodDave] #344799
06/12/09 04:02 PM
06/12/09 04:02 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Puff Puff Pass...
Re: Hemi pistons in 318 ? [Re: 1_WILD_RT] #344800
06/12/09 04:06 PM
06/12/09 04:06 PM
houston texas
gremlinsteve Offline
houston texas
the 5.7 piston has a weak crown. usually breaks ring lands off when it sees detonation. i would not use them.
steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: Hemi pistons in 318 ? [Re: gremlinsteve] #344801
06/12/09 04:17 PM
06/12/09 04:17 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Ok after some looking maybe it could work.. 5.7 "hemi" pistons don't look anything like real Hemi pistons... But FWIW the valve notches aren't even close to usable with an inline valve engine...
5.7 "Hemi" piston
Real Hemi Piston...
Re: Hemi pistons in 318 ? [Re: 1_WILD_RT] #344802
06/12/09 06:13 PM
06/12/09 06:13 PM
Kalispell Mt.
Kalispell Mt.
Neither of those pistons look like the stock 5.7 piston. There is just a very gentle curved dome and no notches. The pistons would be far enough below deck to prevent a colission, I realize it will be a little bit of a low compression deal but I have rings bearings pistons rods a block crank, some magnum heads an XE268 cam 1.7 rockers M1 single plane intake, so I could throw a motor together real quick that could make a few hp plus the Hemi parts are very light weight so it should rev very easily.
Re: Hemi pistons in 318 ? [Re: HotRodDave] #344803
06/12/09 10:32 PM
06/12/09 10:32 PM
Down South
DaKuda Offline
DaKuda  Offline
Down South
WHY????.....
Re: Hemi pistons in 318 ? [Re: 1_WILD_RT] #344804
06/12/09 11:00 PM
06/12/09 11:00 PM
MN
hemidup Offline
hemidup  Offline
MN
5.7 "Hemi" piston
Real Hemi Piston...
That picture of the 5.7 Hemi piston is definatly an aftermarket piston.
Jerry Williams.
