Post deleted by Defbob
[Re: gmachinedart1]
#344003
06/11/09 01:04 PM
06/11/09 01:04 PM
Re: Mcandless 360 w/vibration,help
#344004
06/11/09 03:06 PM
06/11/09 03:06 PM
Posts: 137 LI, new york
gmachinedart1
LI, new york
Maybe he didnt bal. it correctly
\ maybe the pressure plate and disc needed the same ???
Thats what I'm thinking The p/p was also ck'd and balanced
#344006
06/11/09 06:28 PM
06/11/09 06:28 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
There you go Justin, I bet thats it.. when we spoke last, I forgot the Pressure Plate needs to be balanced to the flywheel, so thats the area, I recommend looking into...
[Re: HMcCandless_Jr]
#344008
06/15/09 10:23 PM
06/15/09 10:23 PM
gmachinedart1
LI, new york
If you would like for me to call you PM me your number and I will be glad to call you. I have had this happen many times with customers and I have an easy solution.
Herb Jr
Herb,I sent you a PM
thanx justin
#344009
06/16/09 07:42 AM
06/16/09 07:42 AM
Posts: 15,493 the boonies
aarcuda
the boonies
Herb Jr
so what's the fix? I'm curious
[Re: aarcuda]
#344010
06/16/09 11:35 AM
06/16/09 11:35 AM
Posts: 401 NC
HMcCandless_Jr
NC
#344011
06/18/09 10:01 AM
06/18/09 10:01 AM
gmachinedart1
LI, new york
I purchased this used flywheel described as a 360 externally balanced piece,but when I bolted it up to my 360 it vibrated like crazy.It felt the same as the zero balanced flywheel I had mistakenly installed previously.From what I understand the 360 wheels usually have three very large balance holes on the back side about half way out from the center.Any pics or info is appreciated. thanx justin
#344014
06/23/09 12:36 PM
06/23/09 12:36 PM
Jeepmon
Sunnyvale, CA
Proper balancing,
Can you be more specific? Obviously, if we all pulled our motors, tore it down and have everything balanced to fit, thats the proper way.. But what do you do once the motor is together and already in the car?
