Setting Front Ride Height?? #343329
06/10/09 04:24 PM
06/10/09 04:24 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
What is the proper way of setting front ride height? Is there a standard distance from the LCA bumper to the frame, or anything else that should be taken into account?
FYI: I'm getting ready to weld on a couple tabs for a front coil over conversion on my 66 Dart and want to make sure I order the correct shocks.
Re: Setting Front Ride Height?? [Re: mopowers] #343330
06/10/09 05:03 PM
06/10/09 05:03 PM
Belle River
Q
QUIKFISH1850 Offline
Q
Belle River
Here are the shocks I used 10" and a picture of them installed but I did not use the upper blocks I welded a tube it the upper cross member and I also moved the lower mounts out further.
Re: Setting Front Ride Height?? [Re: QUIKFISH1850] #343331
06/10/09 05:30 PM
06/10/09 05:30 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Do you happen to have the part # or length of the shocks?
Also, do you still have the upper blocks?
Lastly, how much front end travel do you have?
Re: Setting Front Ride Height?? [Re: mopowers] #343332
06/10/09 10:51 PM
06/10/09 10:51 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Re: Setting Front Ride Height?? [Re: mopowers] #343333
06/11/09 08:03 AM
06/11/09 08:03 AM
Belle River
Q
Q
Belle River
The shocks I used are 122-ddr4855b QA1's I have almost full travel on them about 4" the car sits higher then I want but I have oil pan ground cleance isues. It will go lower, perhaps I can take some more picture's of it now finished.
