Master Cutoff Question #343179
06/10/09 11:57 AM
06/10/09 11:57 AM
oregon
ramcharger1964 Offline OP
oregon
Hoes NHRA allow a solenoid shutoff switch like those by Painless Perf or do they need to be completely mechanically operated?
Hell B!tch Racing Co.
Re: Master Cutoff Question [Re: ramcharger1964] #343180
06/10/09 12:01 PM
06/10/09 12:01 PM
Kentucky
sc301v Offline
sc301v  Offline
Kentucky
They are allowed
Re: Master Cutoff Question [Re: ramcharger1964] #343181
06/10/09 12:13 PM
06/10/09 12:13 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
WOAH! STOP. I was in actual contact with NHRA over this issue a couple years ago and the answer was flat out NO!
So unless you have contacted NHRA resently I would advise doing so before you buy and install this.
The reason that was given was is if the control wire going from the on/off button was pinched (grounded) in a collision the battery disconnect would turn back on!
SRT DEMON ONE SEAT
Re: Master Cutoff Question [Re: Ron Silva] #343182
06/10/09 12:54 PM
06/10/09 12:54 PM
NC
chris3 Offline
chris3  Offline
NC
I have just finish dealing with this cut-off situation with NHRA/IHRA and wiring it to work with an alternator. The switch has to be a manual switch, which can be cut-off out side of the car and clearly marked. Certain et's have to have a push/pull, with off being pushed inward. The handle has to extend out beyond the bumper/back of the car.
Check into it carefully, before your buy and install.
Re: Master Cutoff Question [Re: chris3] #343183
06/10/09 01:22 PM
06/10/09 01:22 PM
Kentucky
sc301v Offline
sc301v  Offline
Kentucky
Wow!!Interesting..I actually know some prominent chassis builders that have been doing this for several years now on NHRA super comp and super gas cars.
Re: Master Cutoff Question [Re: chris3] #343184
06/10/09 01:36 PM
06/10/09 01:36 PM
oregon
oregon
I just spoke wit Jonathan Adams, NHRA Div 7 Director. He siad that this type of switch is legal and fully in compliance with the intent of the rule as long as it cuts off ALL elect supply to ALL parts of the vehicle ()Motor, pump, fan, etc...)
Has anyone heard anything different from an NHRA rep?
