Re: TTI headers Issue w/ #3 [Re: 71383beep] #342887
06/16/09 10:50 PM
06/16/09 10:50 PM
Wichita Kansas
CH3NO2 Offline
CH3NO2  Offline
Wichita Kansas
dimple it. the tube. Everything needs a adjustment, right?
Engine by DeTar http://www.kansasbadman.com
Re: TTI headers Issue w/ #3 [Re: CH3NO2] #342888
06/16/09 11:06 PM
06/16/09 11:06 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
I have the same headers but on Edelbrock heads and STILL tight.
Bottomline they are $$$ and still rust. UGH. NEXT TIME I will go with manifolds or SS.
WHO MAKES SS? I'd pay TWICE what I paid for the TTI's. I think XV makes em but not for torsion bar equiped Mopars.
Could just send these guys my set of dented-to-fit (by the bellhousing) TTI's to copy in SS!
http://www.stainlessheaders.com/customheaders
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: TTI headers Issue w/ #3 [Re: 71TA] #342889
06/17/09 05:46 PM
06/17/09 05:46 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
I have the same TTI headers on my 71 Charger R/T 440 AND I have lots of clearance at the number 3 wire . I never burnt a boot anyware and I run the standard plugs. My TTI headers are dimpled already in that area so there is extra clearence. I have had them on the car for 8 years now with about 75 1/4 mile passes without ANY issues. I wonder if you got a very early set. I also run a Firecore set of wires (the set for stock manifolds ) and they fit good .
Re: TTI headers Issue w/ #3 [Re: 71TA] #342890
06/17/09 06:00 PM
06/17/09 06:00 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
That's a pretty bad azz company! I'll have to email them for a quote on a turbo manifold. hopefully it will be reasonable
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: TTI headers Issue w/ #3 [Re: HealthServices] #342891
06/17/09 06:44 PM
06/17/09 06:44 PM
IL
71383beep Offline OP
IL
Well I went ahead and dimpled them.
What paint or selaer can i put on these to prevent rust, etc.
I stuck with the standard autolites. I tried a shorty, but I didn't like where the electrode ended up.
I can fit a sleeve on there now though.
'73 GK6 Challenger Rallye - 340 4-Speed
Re: TTI headers Issue w/ #3 [Re: 71TA] #342892
06/17/09 09:35 PM
06/17/09 09:35 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
for the price, I don't see why TTI's aren't made from 409 stainless. material cost isn't that much more than mild steel....
2017 Grand Cherokee Overland
Re: TTI headers Issue w/ #3 [Re: patrick] #342893
06/18/09 10:22 AM
06/18/09 10:22 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Whats diff between 409SS and other types. Maybe I could ASK TTI if they can duplicate thier headers outta SS.
I'll contact them today.
Wonder what wall thickness?
Re: TTI headers Issue w/ #3 [Re: 71383beep] #342894
06/18/09 11:31 AM
06/18/09 11:31 AM
michigan
black64 Offline
black64  Offline
michigan
You might want to check out these made by accel to see if it would work. They have ceramic on the boots.
Re: TTI headers Issue w/ #3 [Re: 71TA] #342895
06/18/09 12:21 PM
06/18/09 12:21 PM
Newburgh, NY
Old_Moparz Offline
Old_Moparz  Offline
Newburgh, NY
Thanks for posting that link, I've been hunting around for stainless on line & that website had never come up before.
Re: TTI headers Issue w/ #3 [Re: Old_Moparz] #342896
06/18/09 12:26 PM
06/18/09 12:26 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Let me know if you find out anything.
Re: TTI headers Issue w/ #3 [Re: 71TA] #342897
06/18/09 01:04 PM
06/18/09 01:04 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
400 series stainless is magnetic. it gets it's corrosion resistance from high chromium content, IIRC. it has good workability, weldability. most OEM exhaust systems on cars since the late early 90's are 400 series stainless. the Y pipe on my 5th ave ('86) was 409, had a coat of surface corrosion on it, but still solid as a rock when I took it to the metal recyclers in '07...car spent it's life either in michigan or on the california shore, so it had a fair amount of salt exposure.
300 series stainless is non-magnetic, gets most of it's corrosion resistance from high nickel content. it's more expensive, can be polished, bends ok (not as good as 400 series), somewhat susceptible to thermal fatigue--cracks can develop in welds with lots of thermal cycling, much pricier than 400 series
granted it's not as pretty, but I prefer 400 series for exhaust work. it's cheaper and more resistant to thermal fatigue. it can be ceramic coated if you want it pretty.
Re: TTI headers Issue w/ #3 [Re: 71383beep] #342898
06/18/09 01:12 PM
06/18/09 01:12 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I use these, but I'm not sure you can fit one in there. That's real tight. I'd be expecting TTI to do something to help. I have 2" Doug's on my 440 and the gap is larger than that.
http://cgi.ebay.com/ebaymotors/Set-of-8-...bayphotohosting
Re: TTI headers Issue w/ #3 [Re: 71TA] #342899
06/19/09 09:48 AM
06/19/09 09:48 AM
Newburgh, NY
Old_Moparz Offline
Old_Moparz  Offline
Newburgh, NY
I sent an email yesterday asking the cost of a stainless set of headers & was told they'd be around $1300 for 304 SS, & $1100 for mild steel. Too much for my budget, but probably not out of line for custom work. I suppose if you had a car that nobody made headers at all for, it would be the way to go.
Re: TTI headers Issue w/ #3 [Re: 71383beep] #342900
06/19/09 10:53 PM
06/19/09 10:53 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
OK, did a little bit of research. Get the shorty plugs in the same heat range, and use this heatshield on a new set of FireCores !
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: TTI headers Issue w/ #3 [Re: sunroofgtx] #342901
06/19/09 11:31 PM
06/19/09 11:31 PM
So Cal
So Cal
I was wondering when you actually post a picture.
Re: TTI headers Issue w/ #3 [Re: HealthServices] #342902
06/20/09 12:14 AM
06/20/09 12:14 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Wow - guess the angled plugs on my Edelbrocks really helped me there. Never knew.
Ride eternal, shiny and chrome
