Re: VIN Stamping: MYTH or FACT
[Re: Bull1tt]
#342557
06/18/09 08:39 AM
06/18/09 08:39 AM
Posts: 75,125 A Banana Republic near you.
JohnRR
There is no vin stamping on the pan rail but I did find what looks to be a vin stamp on top of the bell housing right where the trans lines up? Was there something peculiar to the 68 cars?
That's where it's supposed to be on a '68 engine.
What he said , that's the 68 location , if the car has an auto trans the trans is stamped in the same location as the engine , 4 speed will be stamped down on the side same as 69 up ...
[Re: JohnRR]
#342558
06/18/09 09:16 AM
06/18/09 09:16 AM
Posts: 21,555 N.E. OHIO, USA
A12
N.E. OHIO, USA
'68 (rr short block) engine/VIN location - driver's side/top/rear
MikeR
[Re: west]
#342561
06/27/09 12:37 AM
06/27/09 12:37 AM
Posts: 406 California City, CA
dart440
California City, CA
The warranty replacement in my 69 GTX was NOT stamped at the dealer with the VIN, it was left unstamped (had dealer service records with the car).
When you work on Spaceships for a living, how bad can a workday be?
[Re: DAYCLONA]
#342562
03/25/11 11:38 PM
03/25/11 11:38 PM
Posts: 1,265 New York, USA
Chargerfan68
New York, USA
On a 68 engine where the vin is stamped on the upper bellhousing area by the oil pressure unit, would they have used the same machine for the vin , even though that area is curved? It is not a flat pad like on post 68's. Or, was it stamped by hand? Thanks, Greg. ![](/ubbthreads/images/graemlins/smile.gif)
[Re: A12]
#342563
03/26/11 12:49 AM
03/26/11 12:49 AM
Posts: 417 Caledon, Ontario
smac77
Caledon, Ontario
The EAD pad from the above block, pretty angled and the HP and "2" in an odd location?
Theories on the different font ??
Restoration, Sales and Canadian Distributor For: AMD Sheetmetal Wizzard Direct Fit, Bolt In Aluminum Radiators Legendary Interiors SSBC & Wilwood Brakes Control Freak Suspensions Fine lines Tubing and many more... www.macleanclassics.com
[Re: ConvertiBee]
#342565
03/26/11 01:20 AM
03/26/11 01:20 AM
Posts: 14,471 renton, Washington
ph23vo
renton, Washington
I'm certainly no expert, but I've seen more than a few VIN pads over the years. If I were looking at a car to buy, and I saw the pad stamped that way, I would immediately think "fake", and base my buying decision on it being a non-numbers matching car.
...and (I believe), a 1971 block would have the FULL vin on it.
also the bevel on top of the pad is about twice as deep as any other block i have seen..
[Re: A12]
#342566
03/26/11 01:34 AM
03/26/11 01:34 AM
JohnRR
That does not look out of the ordinary for a 383 and I think that is the location of the 2 for second shift stamp , I'm pretty sure I have at least one like that .
[Re: 472 R/T SE]
#342567
03/26/11 06:55 AM
03/26/11 06:55 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
yes it was true where I worked but no many ever bothered
I'll chime in on that too- I worked for Ma Mopar since the 80's and we never bothered. Already getting shorted on the labor time to do the job and you want me to do what?
BTW- The vin on the original trans from my Duster is screwed up, off one digit in the middle.
[Re: Chargerfan68]
#342570
03/26/11 08:43 AM
03/26/11 08:43 AM
Posts: 1,945 Grand Rapids MI
N9671X2
Grand Rapids MI
Thanks, Greg.
I think the 68s were stamped by hand. I bought a numbers motor/auto tranny 68 hemi charger 10 years ago. The drivetrain was out of the car, but untouched to the point of original plug wires. Car had been of the road since the 70s. I wiped the oil/grime off to check the numbers, the block only had 5 numerical digits, it was missing one of the middle numbers. Both tranny and motor numbers were really sloppy, I really got the impression they were done by hand and not machine like later years.
[Re: 6PakBee]
#342572
03/26/11 12:35 PM
03/26/11 12:35 PM
Posts: 576 Hr up from KCK
451 D*O*D*G*E
Hr up from KCK
My opinion on the font is that the hardened steel would break and they would slide a new number on and the maufactuer of the stamp might have been different.
1970 Challenger R/T clone
2010 Dodge Journey R/T black,awd,
[Re: ph23vo]
#342574
03/26/11 05:56 PM
03/26/11 05:56 PM
Posts: 4,872 connecticut
pnypwr
connecticut
the "original" block for my 68 runner is weird also...I have knowledge back to 1970 of the car and motor wasnt ever changed from then on...the block has a mid 66 casting its stamped D383 on the pad no other numbers except but has 2 numbers with an x over them. the julian dating puts it oct 67 assy date and the dates in the bearing inserts are 9 67 my car has a spd of 1 68 so in the assy window, i cant find a vin stamp on it anywhere so who knows, but it had all the correct parts intake exh heads pan etc and all dates are right in line with the engine...is it assy line engine, got me...
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
