Re: VIN Stamping: MYTH or FACT
#342438
06/09/09 09:23 PM
06/09/09 09:23 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
dealerships' were suppose to stamp the VIN on the warranty motors.
I've never seen a shred of evidence to support that story. If anyone has any I'd love to see it (Factory Bullitins, Memo's etc.). It's possible that some dealership owners had internally unique procedures to track engine warranty work but nothing from the factory I've ever seen proof of.
IF it were ever to happen they would have stamped a new block (Warranty/Service replacement, etc.) not re-stamped an old block that already had a number (that block pic you posted appears to have other numbers under the new ones?).
So, first you'd need to establish if the block is a W/S replacement, then have the paperwork supporting that it was actually replaced under warranty at the dealer back in the day, and even then it's still not the original #'s block.
[Re: imfixinmopars426]
#342440
06/09/09 09:25 PM
06/09/09 09:25 PM
Posts: 18,165 Mass
DAYCLONA
Mass
i seen a few 4 spds stamped,and then restamped, the same number,but kinda over the original one.
....Yep I done that before,....I mean, seen that before
[Re: ScottSmith_Harms]
#342441
06/09/09 09:45 PM
06/09/09 09:45 PM
Posts: 11,855 Georgetown Ontario Canada
anlauto
Just to clarify.... This is supposed to be the engine that blew up and was taken out(damage to the lower skirt of #4 cylinder) ....therefore having the numbers stamped at the factory.... It was removed from the car and replaced under warranty back in 1971 and somehow ended up in Ohio some 38 years later. What did the dealers do with the dicarded engine blocks back then?
CHECK OUT MY NEW WEB SITE !
[Re: ph23vo]
#342451
06/09/09 11:14 PM
06/09/09 11:14 PM
Posts: 9,407 Brantford Ontario
69_SIX_PACK
Brantford Ontario
Seems like someone went fishing for a sucker: He must have figured you for someone with lots of $$$. Too bad it didn't work out. You should ask him how long the wait would be for a spare matching number tranny would be Dave
[Re: anlauto]
#342453
06/09/09 11:18 PM
06/09/09 11:18 PM
Posts: 75,274 A gulag near you.
JohnRR
A gulag near you.
discarded them into the scrap pile .
I wish I had a picture of the 70 hemi cuda rebody remains from a dealer in Mass. back in the early 80's , the original body sitting on top of their scrap pile out back .
[Re: anlauto]
#342454
06/09/09 11:24 PM
06/09/09 11:24 PM
Posts: 4,801 Ontario, Canada
mccannix
Ontario, Canada
Well Alan, if this one doesn't pan out and since the warranty repacement 440 motor wasn't with the car either when you got it, watch for someone now doing a better job of restamping and contacting you claiming they have the warranty replacement motor....now where'd I put my stamps.
