Page 2 of 13 1 2 3 4 12 13
Re: VIN Stamping: MYTH or FACT [Re: JohnRR] #342437
06/09/09 09:22 PM
06/09/09 09:22 PM
Georgetown Ontario Canada
anlauto Offline OP
anlauto  Offline OP
It was removed from the car while under warranty?
is that the STORY you were told by someone trying to FLEECE you ?
NO...fortunatly enough the original owner is still alive. I called him tonight to ask, again, what happened to the original motor....To the best of his memory, the block had a loud knock, and he seems to recall damage to the oil pan. Remember, he was in his early 20's and not really a mechanically inclined, just a young guy with a cool car he bought new.
He took it back to the dealer and had it replaced. It wasn't much long after that, that he sold the car keeping it only one year.
CHECK OUT MY NEW WEB SITE !
Re: VIN Stamping: MYTH or FACT #342438
06/09/09 09:23 PM
06/09/09 09:23 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
dealerships' were suppose to stamp the VIN on the warranty motors.
I've never seen a shred of evidence to support that story. If anyone has any I'd love to see it (Factory Bullitins, Memo's etc.). It's possible that some dealership owners had internally unique procedures to track engine warranty work but nothing from the factory I've ever seen proof of.
IF it were ever to happen they would have stamped a new block (Warranty/Service replacement, etc.) not re-stamped an old block that already had a number (that block pic you posted appears to have other numbers under the new ones?).
So, first you'd need to establish if the block is a W/S replacement, then have the paperwork supporting that it was actually replaced under warranty at the dealer back in the day, and even then it's still not the original #'s block.
Re: VIN Stamping: MYTH or FACT #342439
06/09/09 09:23 PM
06/09/09 09:23 PM
across the river from Portland...
472 R/T SE Offline
472 R/T SE  Offline
yes it was true where I worked but no many ever bothered
Thanks Fred, you're the first person to ever comment on that claim.
So did the dealerships' use the same style font punch as the factory? So to be correct, it would have the tags' on the sides of the motor and stamped up by the distributor on that pad W/S or whatever it is?
Re: VIN Stamping: MYTH or FACT [Re: imfixinmopars426] #342440
06/09/09 09:25 PM
06/09/09 09:25 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
i seen a few 4 spds stamped,and then restamped, the same number,but kinda over the original one.
....Yep I done that before,....I mean, seen that before
Re: VIN Stamping: MYTH or FACT [Re: ScottSmith_Harms] #342441
06/09/09 09:45 PM
06/09/09 09:45 PM
anlauto Offline OP
anlauto  Offline OP
Just to clarify....
This is supposed to be the engine that blew up and was taken out(damage to the lower skirt of #4 cylinder)
....therefore having the numbers stamped at the factory....
It was removed from the car and replaced under warranty back in 1971 and somehow ended up in Ohio some 38 years later.
What did the dealers do with the dicarded engine blocks back then?
Re: VIN Stamping: MYTH or FACT [Re: anlauto] #342442
06/09/09 09:57 PM
06/09/09 09:57 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Those numbers were not stamped at the factory regardless of the history/story.
Re: VIN Stamping: MYTH or FACT [Re: anlauto] #342443
06/09/09 10:01 PM
06/09/09 10:01 PM
Somewhere near Palm Springs
ConvertiBee Offline
ConvertiBee  Offline
I'm certainly no expert, but I've seen more than a few VIN pads over the years. If I were looking at a car to buy, and I saw the pad stamped that way, I would immediately think "fake", and base my buying decision on it being a non-numbers matching car.
...and (I believe), a 1971 block would have the FULL vin on it.
[img]https://photos.google.com/search/_tra_/photo/AF1QipP622C0UgUgrRn9SDVmwoPXVW4gJ4A2UcAzWOit[/img]
'69 GTX 440 D21 A34 N96
'70 Coronet 383 'Vert
'71 Demon 340 SixPack 4-Speed
'72 Cuda 340 FE5
'74 Kawasaki Z1, and...
(12) Japanese Enduro's and SuperBikes from the 1970's! smile
Re: VIN Stamping: MYTH or FACT [Re: ConvertiBee] #342444
06/09/09 10:12 PM
06/09/09 10:12 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
When I worked in the dealership back in the 70s the factory warrenty rep would smack the block with a hammer to damage it so it couldn't be reused and then it got scrapped. They were never reused.
Re: VIN Stamping: MYTH or FACT [Re: ConvertiBee] #342445
06/09/09 10:12 PM
06/09/09 10:12 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
No, the 71 would have the partial VIN like this example
Re: VIN Stamping: MYTH or FACT [Re: ScottSmith_Harms] #342446
06/09/09 10:19 PM
06/09/09 10:19 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Was the engine and trans stamped one right after the other with the same tool?
I have the origonal drivetrain to my dad's Challenger(he is the origonal owner) The trans has one number that is stamped wrong. I havn't looked at the engine to see if it has the same "wrong" letter.
Re: VIN Stamping: MYTH or FACT [Re: burdar] #342447
06/09/09 10:21 PM
06/09/09 10:21 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes
Re: VIN Stamping: MYTH or FACT [Re: ScottSmith_Harms] #342448
06/09/09 10:24 PM
06/09/09 10:24 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Then the block should have the same "wrong" stamping. I'll have to check that out.
Re: VIN Stamping: MYTH or FACT [Re: Furyman] #342449
06/09/09 10:29 PM
06/09/09 10:29 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
i've looked at lots of pads...#'s can be all over the place.But...that engine pad does not look right to me...the fonts look off.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: VIN Stamping: MYTH or FACT [Re: 69CoronetRT] #342450
06/09/09 10:57 PM
06/09/09 10:57 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
also notice the PAD is twice as deep as most you see... indicating its been shaved..also the font is way way off as the spacing off the trans stamp would be the same so yes this is a FRAUD dan
Re: VIN Stamping: MYTH or FACT [Re: ph23vo] #342451
06/09/09 11:14 PM
06/09/09 11:14 PM
Brantford Ontario
69_SIX_PACK Offline
69_SIX_PACK  Offline
Brantford Ontario
Seems like someone went fishing for a sucker:
He must have figured you for someone with lots of $$$.
Too bad it didn't work out.
You should ask him how long the wait would be for a spare matching number tranny would be
Re: VIN Stamping: MYTH or FACT [Re: 69_SIX_PACK] #342452
06/09/09 11:18 PM
06/09/09 11:18 PM
Indiana
Rocko Offline
Rocko  Offline
Indiana
The look on that fish's face just made my day.
Re: VIN Stamping: MYTH or FACT [Re: anlauto] #342453
06/09/09 11:18 PM
06/09/09 11:18 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Just to clarify....
discarded them into the scrap pile .
I wish I had a picture of the 70 hemi cuda rebody remains from a dealer in Mass. back in the early 80's , the original body sitting on top of their scrap pile out back .
Re: VIN Stamping: MYTH or FACT [Re: anlauto] #342454
06/09/09 11:24 PM
06/09/09 11:24 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Just to clarify....
Well Alan, if this one doesn't pan out and since the warranty repacement 440 motor wasn't with the car either when you got it, watch for someone now doing a better job of restamping and contacting you claiming they have the warranty replacement motor....now where'd I put my stamps.
Re: VIN Stamping: MYTH or FACT [Re: mccannix] #342455
06/09/09 11:34 PM
06/09/09 11:34 PM
Buffalo, NY U.S.A.
MrNormsTA Offline
MrNormsTA  Offline
Buffalo, NY U.S.A.
I wouldn't sweat it, but you might want to change your ad back to non-matching motor now.
This is one of the prime reasons I personally don't care much about the whole numbers matching gig and never did.
Re: VIN Stamping: MYTH or FACT [Re: mccannix] #342456
06/09/09 11:39 PM
06/09/09 11:39 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
well at least they can use this thread to correct thier mistakes for the next attempt.
