msd dist advance? #342250
06/09/09 03:01 PM
06/09/09 03:01 PM
LI, new york
gmachinedart1 Offline OP
LI, new york
I'm planning on purchasing a #8534 MSD dist. for my 360.I noticed in the specs description the least amount of mechanical advance i can dial in is 18 degrees.I usually run around 20-21 deg.initial so I would like to dialin 13-14 deg. mechanical adv. to achieve my total of 34.Has anyone played or run into this ?Is there a way to achieve what i need?
thanx
justin
Re: msd dist advance? [Re: gmachinedart1] #342251
06/09/09 03:49 PM
06/09/09 03:49 PM
Q
Quicktree Offline
Quicktree  Offline
Q
is this a race set up? run the black bushing 1 light silver and 1 light blue spring. that usally works for most.
Re: msd dist advance? [Re: gmachinedart1] #342252
06/09/09 04:00 PM
06/09/09 04:00 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
thanx
justin
You mean real initial set before it runs or idle advance which is up anywhere from 5 to 18 deg of initial???
Re: msd dist advance? [Re: gmachinedart1] #342253
06/09/09 04:51 PM
06/09/09 04:51 PM
Colorado
506RR Offline
506RR  Offline
Colorado
Call Don at FBO Systems! I just purchased his bushing kit for my MSD Distributor (Big Block). He sells a 10 and 14 degree bushing for MSD distibutors!
FBO is the only place I know of that you can get these bushings!
http://www.4secondsflat.com/
Re: msd dist advance? [Re: 506RR] #342254
06/10/09 09:43 AM
06/10/09 09:43 AM
LI, new york
LI, new york
Thats what I was looking for!
thanx
