Ladder bar guys where are your bars?
#342079
06/09/09 10:30 AM
06/09/09 10:30 AM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
Been thinking about playing with my ladder bar setup on my Challenger and was wondering where most of you guys ran yours at. Mine are currently in the middle. You guys that have tried lowering/raising the bars what were your results?
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Ladder bar guys where are your bars?
[Re: MR_P_BODY]
#342081
06/09/09 10:44 AM
06/09/09 10:44 AM
Posts: 644 Minnesota
Barnstorm
Minnesota
Lower hole usually works for non NHRA prepped tracks.
The little old lady from Pasadena is back!
[Re: bigtimeauto]
#342084
06/09/09 12:56 PM
06/09/09 12:56 PM
If you have a good converter I like the middle hole...You must raise the wheelie bars up, or they will unload the tires and the car will spin and become very inconsistant...poppaj
[Re: mikemotorhead]
#342086
06/09/09 01:13 PM
06/09/09 01:13 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
Middle hole is to generic it depends where the crossmember is mounted, tire size and the ride height of the car
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: bigtimeauto]
#342087
06/09/09 01:25 PM
06/09/09 01:25 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
with my car at ride height and weight I set my bars at 3deg down in the front and it seems to be working well have yet to try any other holes.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: Hunted Duck]
#342090
06/09/09 02:15 PM
06/09/09 02:15 PM
Jacob Pitt
Mansfield, Tx
Interesting stuff guys. I also heard that on the bottom hole the car will work better on the starting line but lose e.t. down track. Any experience with this?
[Re: rebel]
#342092
06/09/09 03:01 PM
06/09/09 03:01 PM
Posts: 52,972 Romeo MI
MR_P_BODY
just clarifying something for myself on this post, sorry not trying to hijack, but if the ladder bars are pointing uphill, wouldn't that make the car prone to wheelstanding?
Yes if it doesnt bounce the tire of the ground from too hard of a hit ![](/ubbthreads/images/graemlins/wave.gif)
[Re: rebel]
#342094
06/10/09 09:59 AM
06/10/09 09:59 AM
Posts: 10,023 Frostbitefalls MN (Rocky&Bullw...
gregsdart
A lot depends on the bar hole placement in relation to the neutral line, wheelbase, total torque at the hit, CG height and front rear location, trans type,,,,,, My dart is 106 WB with 3000 lbs, torqueflite, 6400 stall, 4.56 gears, a little high on motor placement, with 800 torque at the flexplate on the hit. If I am slightly above the neutral line in the middle hole, it rises slower due the rear being forced up at the start. If I put it in the bottom hole, it jerks the tires out of the beams at the same time the rear squats, and rotates around the CG in aa hurry, hitting the 66 inch wheeliebars so hard it unloads the tires. I can feel it happen. This is with a 33.6 x15x15 tire, the 33x 15 radial slicks spun, and would lift the front slower, although they did 60 ft faster by at least .02
