Finally got my 59* w-9 fired last weekend and am having some of the same issues I always had. My previous E-headed 416 ran a best of
6.22@110 with a 1.39 avg.60',launching@3400. Allways had my shift light set at 6500 to shift but can't ever hit that rpm except for the burnout. i have a 2800lb.70 cuda /glide/4.86 rear/32x16x15's./ron's toilet on m-5.As soon as I hit about 57-5800,it starts to fall off and a spudder starts, so I allways short shifted and cross the 660'@ 6100.
The first thing i did was call Ron's and got a high speed bypass. Didn't help!Then later on tried a new fuel pump from Ron's, again not working!Tried nozzles-pills and my sons' barrell valve setup from his 416 still no help.
Now I have my new w-9and last weekend left everthing else the same including the 3400 launch and only went 1.45 60' but e/t hit
6.14@113.8 still crossing the line at 6100 and still studdering the 1-2 shift thing
last night I changed my msd 7al3 to a new one along with dist, cap/rator wires and coil to see if this will work. i'm running out of ideas guy's and I know this thing has to dangle in the 1/8 mile. Am i to far off to guess a 5.8 area or so?
Thanks guy's
