AAR valvle cover repair #340652
06/07/09 03:15 PM
06/07/09 03:15 PM
Pennsylvania
A0M397X Offline OP
A0M397X  Offline OP
Pennsylvania
Does anybody know he source for replacement wire holders for the valve covers. I have a few broken looms and remember somewhere there is a place to get replacements.
Thanks!
Re: AAR valvle cover repair [Re: A0M397X] #340653
06/07/09 03:59 PM
06/07/09 03:59 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Re: AAR valvle cover repair [Re: gtx6970] #340654
06/07/09 04:40 PM
06/07/09 04:40 PM
Pennsylvania
A0M397X Offline OP
A0M397X  Offline OP
Pennsylvania
No, not those. I need the bendable metal tabs and the larger, tubular trough that hold the alternator wires, etc. These are spot welded? on I think.
Re: AAR valvle cover repair [Re: A0M397X] #340655
06/07/09 07:01 PM
06/07/09 07:01 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Pete's Restoration in CA supplied them @ one time. I believe his handle on Moparts is 70cooda.
Re: AAR valvle cover repair [Re: rayztoy] #340656
06/07/09 09:15 PM
06/07/09 09:15 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Pete
has taken his site down/offline for the summer due to business/work constraints. He did make the valve cover wiring harness clips but not sure of the wiring harness trough
Re: AAR valvle cover repair [Re: rayztoy] #340657
06/08/09 02:18 PM
06/08/09 02:18 PM
Minnesota
3twos Offline
3twos  Offline
Minnesota
His moparts handle is or was at one time 1970mopar. He had the small bendable clips and they were real inexpensive. You can make the larger piece from a sheetmetal.
Al & Sheila
Re: AAR valvle cover repair [Re: A0M397X] #340658
06/08/09 03:17 PM
06/08/09 03:17 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Contact this moparts member for them ...
hemi70se
Re: AAR valvle cover repair [Re: A0M397X] #340659
06/08/09 06:28 PM
06/08/09 06:28 PM
MD
floyd Offline
floyd  Offline
MD
Moparts user "RP's R/T's" makes and sells the tabs and offers a valve cover resto service. He did my T/A valve covers and they turned out great.
Re: AAR valvle cover repair [Re: A0M397X] #340660
06/08/09 08:36 PM
06/08/09 08:36 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Not all of them had the big "trough". I have seen both styles on original cars.
