tetraethyl lead addative, does it work? #340353
06/07/09 08:28 AM
06/07/09 08:28 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
found a couple places selling it and wondered if it worked?
says it has the real tetraethyl lead in it and 3 oz will raise octane 8 points.and help save valve seats.
Re: tetraethyl lead addative, does it work? [Re: dirt] #340354
06/07/09 11:20 AM
06/07/09 11:20 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
no one has tried this stuff?
Re: tetraethyl lead addative, does it work? [Re: dirt] #340355
06/07/09 11:33 AM
06/07/09 11:33 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i would think it depends on the brand of product and result you want that thay need to know more.the % in the formula has a lot to do with it.i think a gram or so a gallon is what is used.there are other ways to raise octane.
Re: tetraethyl lead addative, does it work? [Re: dirt] #340356
06/07/09 11:42 AM
06/07/09 11:42 AM
Utah
O
orangemonster Offline
super gas
super gas
O
Utah
I have used a tetraethyl lead additive acouple of years ago on a poly 318 that I had freshened up and did not put hardened seats in,guides valve job,seats were not sunk,and put about 3 thousand miles on it but hav'nt taken it apart to see if they were showing signs of sinking.3grand in miles is a little short but may see seat widening,with out the lead.
Re: tetraethyl lead addative, does it work? [Re: orangemonster] #340357
06/07/09 12:22 PM
06/07/09 12:22 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I'm a little surprised it's available for sale. Don't get it on your skin.
Re: tetraethyl lead addative, does it work? [Re: dthemi] #340358
06/07/09 12:46 PM
06/07/09 12:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I a little surprised it's available for sale. Don't get it on your skin.
It bad stuff alright, I tried it about 20 years ago
and it does work..... I didnt think it was legal to
sell anymore
Re: tetraethyl lead addative, does it work? [Re: dirt] #340359
06/07/09 01:17 PM
06/07/09 01:17 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I'd guess that 8 points claimed is .8 of a point. That stuff is probably a very, very weak solution. One drop of pure tetraethyl lead on your skin will kill you. Dave
Re: tetraethyl lead addative, does it work? [Re: quickd100] #340360
06/07/09 02:22 PM
06/07/09 02:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The TEL products that I've seen use a carrier such as kerosene to dilute the concentration.
Re: tetraethyl lead addative, does it work? [Re: John_Kunkel] #340361
06/07/09 03:09 PM
06/07/09 03:09 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
here is a link to the site of it.
3 oz to 1gal = 8.0 octane increase.
i thought this would be good for my 440 that has higher compression and non hardened valve seats
link to site
Re: tetraethyl lead addative, does it work? [Re: dirt] #340362
06/07/09 03:50 PM
06/07/09 03:50 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Question is - how cost effective is it?
From the Kemco Oil web site...
Octane Supreme 130
Octane boost-fuel additive that really works. 2-16 point increase on octane. Turn a 93 Octane fuel into 101 with 8 ounces per gallon. CONTAINS LEAD! Fouls O2 sensors and plugs cats. Off road use only
One qt by the case costs $10.42 and 1 qt treats 4 gals. So1.....10.42 + 4 gals of the average 93 octane (roughly 2.75 x 4 gals - yours may be more per gallon) = $21.41 for 4 gals /4 = 5.10 per gal for 101 octane fuel. Can you buy 101 locally for that?
Re: tetraethyl lead addative, does it work? [Re: Sixpak] #340363
06/07/09 04:58 PM
06/07/09 04:58 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
actually it was 3oz makes an 8.0 point octane increase. so 1 qt would treat 10.66 gallons . making 93 into 101.
Re: tetraethyl lead addative, does it work? [Re: dirt] #340364
06/07/09 05:11 PM
06/07/09 05:11 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Just for thought,,, E85 is 105 or higher, less than 2 bucks a gallon, and without the little bit of gas in it you could drink it.
Re: tetraethyl lead addative, does it work? [Re: dthemi] #340365
06/07/09 05:43 PM
06/07/09 05:43 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Now theres a thought how to get the gas out of e85 without
Re: tetraethyl lead addative, does it work? [Re: dirt] #340366
06/07/09 06:09 PM
06/07/09 06:09 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Uh,,,,,,,,,nope.....better check the actual manufacturers web site, what I posted was copied straight from their web site - 8 oz treats 1 gallon.
http://www.kemcooil.com/products.php?cId=4
Re: tetraethyl lead addative, does it work? [Re: Sixpak] #340367
06/07/09 06:43 PM
06/07/09 06:43 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
This from the lnk in his post above.
TREAT RATES R+M/2
0.6Ounces OB-130 to 1 gallon/fuel……….2.0 point octane increase
1.2Ounces OB-130 to 1 gallon/fuel……….3.5 point octane increase
1.8Ounces OB-130 to 1 gallon/fuel……… 5.0 point octane increase
2.4Ounces OB-130 to 1 gallon/fuel……….6.5 point octane increase
3.0Ounces OB -130 to 1 gallon/fuel…….…8.0 point octane increase
6.0Ounces OB-130 to 1 gallon/fuel……..11.0 point octane increase
18Ounces OB-130 to 1 gallon/fuel……..16.0 point octane increase
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Post deleted by Defbob [Re: dthemi] #340368
06/07/09 07:04 PM
06/07/09 07:04 PM
Re: tetraethyl lead addative, does it work? [Re: MoparforLife] #340369
06/07/09 07:15 PM
06/07/09 07:15 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
well holy crap.now i am not sure. there is not much info on the actual web site.
if it does take 8oz then you get 1 octane per ounce added to 1 gallon of gas. thats expensive, i wonder where the other site got its info? one has to be wrong.
wonder how much it takes to keep the valve seats lubed up?
are there any other brands that boost octane? this was just one i came across.
Re: tetraethyl lead addative, does it work? #340370
06/07/09 09:02 PM
06/07/09 09:02 PM
Appalachia
RedRam Offline
RedRam  Offline
Appalachia
do they make that in peach flavor ? I think maybe I did drink it on my last trip to NC
Best way to get the gas out is to not put it in to start with
Yes Fred it can come in many flavors and peach is very common.
Current stock is regular, raspberry and apple
My favorite, raspberry on ice
Re: tetraethyl lead addative, does it work? [Re: RedRam] #340371
06/07/09 11:37 PM
06/07/09 11:37 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I seem to recall there is a concentration limit (4ml/gallon?) of TEL to be able to ship it. I called VP several years ago when I was checking into being a distributor. One of the real high octane fuels had twice the limit of TEL and I asked how they shipped it? Well, there was some hem-hawing and I see now they don't list it on their MSDS for the fuels. I'd just stick with mixing racing fuel in with pump gasoline for my old cars. One gallon of race gas per tank is enough to protect the valve.
As far as separating the gasoline out of E85, I think the addition of water will cause them to separate. I don't think I would drink it even then since you don't know what else is in there. I'd stick with homebrewing for my alcohols needs. You can legally make 100 gallons of beer or wine, a year per person for personal consumption.
Floyd Lippencott IV
Re: tetraethyl lead addative, does it work? [Re: dirt] #340372
06/08/09 01:08 PM
06/08/09 01:08 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
You might check this one out. 48 oz. to 20 gals. for 103 octane.
http://maxlead2000.com/
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
