Headlight Adjustment #336815
06/03/09 01:33 AM
06/03/09 01:33 AM
Easton, Kansas
Moparmedic440 Offline OP
Easton, Kansas
Just got the restoration done on my 72 Roadrunner. My headlights are all over the place. How do I go about adjusting my headlights in my shop at home? Thanks
Re: Headlight Adjustment [Re: Moparmedic440] #336816
06/03/09 01:43 AM
06/03/09 01:43 AM
The Dalles, OR.
Dusted_Ya Offline
Dusted_Ya  Offline
The Dalles, OR.
should be an adjustment screw on top and on the side of each headlight (It's the one with the spring. I like to adjust mine on the road. bring a phillips and a flashlight with you to get it dialed in to taste!
Re: Headlight Adjustment [Re: Dusted_Ya] #336817
06/03/09 09:11 AM
06/03/09 09:11 AM
Not Gabba-NYC, That's For Sure...
dinty68RR Offline
dinty68RR  Offline
Another way to adjust your headlights (low- and high-beams) is to use your garage wall or garage door as a reference (tried and true method). Here's a link to this method, giving step-by-step instructions:
http://www.automedia.com/Aiming_Headlights/ccr20010801ha/1
Also, remember to check that your tires are inflated correctly and your trunk is not full of "stuff" before starting...
Glenn
67 Barracuda Convertible (PP1)
68 Road Runner (LL1, 69,000 Original Miles)
Jim's Auto Parts, Legendary Auto Interiors, Coker Tire
Re: Headlight Adjustment [Re: dinty68RR] #336818
06/03/09 11:35 AM
06/03/09 11:35 AM
Az
Crizila Offline
Crizila  Offline
Az
http://www.automedia.com/Aiming_Headlights/ccr20010801ha/1 Simple, accurate way to go.
Glenn
Fastest 300
