manual shifting 727??? #335611
06/01/09 09:21 PM
06/01/09 09:21 PM
abc440 Offline OP
abc440  Offline OP
I have a 71 charger, 440, 727 tranny. Tranmission shifts fine in drive, all the shift points just fine. If I put in low and try to shift manually, it will not shift from first to second during acceleration or if i let off the gas. Any ideas? Thanks dave
Re: manual shifting 727??? [Re: abc440] #335612
06/01/09 09:39 PM
06/01/09 09:39 PM
scratchnfotraction Offline
your moving the gear selector from 1st to 2nd gear manualy and its not shifting
does it shift when you stop and start in drve?
Re: manual shifting 727??? [Re: scratchnfotraction] #335613
06/01/09 10:01 PM
06/01/09 10:01 PM
abc440 Offline OP
abc440  Offline OP
Yes, it shifts great when you start off in drive, shifts automatic and good shift points. Thanks
Re: manual shifting 727??? [Re: abc440] #335614
06/02/09 05:05 PM
06/02/09 05:05 PM
abc440 Offline OP
abc440  Offline OP
Anybody with these same shifting problems?
Re: manual shifting 727??? [Re: abc440] #335615
06/02/09 05:11 PM
06/02/09 05:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have high does it rev without shifting? If you have your foot to the floor it won't shift until you hit 5000 or more because you're into the kickdown.
Re: manual shifting 727??? [Re: abc440] #335616
06/02/09 05:21 PM
06/02/09 05:21 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
If it won't shift at WOT unless you lift the throttle the throttle pressure linkage needs to be backed off.
Re: manual shifting 727??? [Re: John_Kunkel] #335617
06/02/09 05:46 PM
06/02/09 05:46 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
He says it won'tshift even if he lets off the gas.
Re: manual shifting 727??? [Re: abc440] #335618
06/02/09 05:52 PM
06/02/09 05:52 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
First thought {and the easiest solution}... ...Did you try to readjust your shifter linkage ???
Re: manual shifting 727??? [Re: screamindriver] #335619
06/02/09 06:23 PM
06/02/09 06:23 PM
abc440 Offline OP
abc440  Offline OP
I have the B and M shifter with cable. How do I go about adjusting linkage? Thanks
Re: manual shifting 727??? [Re: screamindriver] #335620
06/05/09 10:05 PM
06/05/09 10:05 PM
abc440 Offline OP
abc440  Offline OP
Thanks guys for all the ideas. I adjusted the cable linkage according to the instuctions I still had from 5 years ago when I installed the shifter. Just freed up the cable connecting to the shift lever on side of tranny and can now shift through the mannually with no problems. Thanks screamindriver!
Re: manual shifting 727??? [Re: abc440] #335621
06/05/09 11:40 PM
06/05/09 11:40 PM
Harrisburg, Pa.
Harrisburg, Pa.
Great news... ...Have'nt been on here for a few days or I'd have answered you...I've had a few B&M cable shifters over the years and burned up more than one... ...The biggest thing about the cable is making sure you have the correct shifter lever because it's a different length depending on the application...Glad to hear everything worked out...
