NE1 tried this aftermarket power window kit 4 E Body?
#335351
06/01/09 07:02 PM
06/01/09 07:02 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
http://cgi.ebay.com/ebaymotors/ws/eBayIS...#ht_4059wt_1005Wondering if it works.... Would put on the correct switches on the door panels for sure, but I was wondering how good would it work...or should I forget about it and just try to find and original setup?? Im am ttired of rolling all 4 manual windows up and down each time I rise or lower the top on the cuda vert. Thanks!
Re: NE1 tried this aftermarket power window kit 4 E Body?
[Re: RokketRide]
#335355
06/01/09 08:38 PM
06/01/09 08:38 PM
Posts: 4,755 Florida
BDW
take a look at these guys
http://www.nu-relics.com/mopar.html
I heard this is the kit XV sells.
Whatever you do, stay away from A1 Electric. It's a total piece of crap. Luckily I tried it out before cutting the panels for the switches. Sent that POS back ASAP!
[Re: BDW]
#335356
06/01/09 10:07 PM
06/01/09 10:07 PM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
I don't see an Ebody version....??
[Re: domingo]
#335359
06/02/09 02:54 AM
06/02/09 02:54 AM
DaytonaTurbo
Manitoba, Canada
Thanks!
The ones I run are made by spal, but are basically the same thing. I've installed these things on two vehicles and they work beautifully. They are quick and easy to install and I find they are able to put more torq onto that window than my arm could by hand. The ONLY downside to them is you have to put a cap on your door panel to hide where the splined shaft for your window cranks comes through. Not a big deal to me but to some it's an issue. I will be buying more of those things in the future, that I can guarantee you.
[Re: DaytonaTurbo]
#335360
06/02/09 07:51 AM
06/02/09 07:51 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Do you have the link for the source of the Spal ones?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: domingo]
#335364
06/02/09 09:05 AM
06/02/09 09:05 AM
Posts: 4,165 Florida
cataclysm80
Are the windows fast the way you installed em without the need to add all those relays recommended on the other thread???
I've installed them for the test fit so far, regulators & tracks without glass. They are fast enough that I was nervous about holding the button down. Without the glass & bump stops installed, the regulators can slide off the tracks going too far up or down (OE setup does the same thing). I'm thinking that once the glass is installed, the extra resistance will slow it down a little, but it should operate at basically the same speed as any modern car with power windows. Note that this is at least a little dependent on the quality of switches you end up with. I didn't have any problems with mine, but if you get a bad switch with worn contacts
Tav
[Re: cataclysm80]
#335367
06/02/09 05:42 PM
06/02/09 05:42 PM
BDW
Read through this, once people are pressed they admit the A1 stuff isn't the greatest. http://www.cuda-challenger.com/cc/index.php?topic=45919.0When I tried them, they went down so fast it broke the rubber bump stop. and it struggled to raise. It was not an adjustment issue, as I did all the testing without the door panels on and the door open. Luckily I didn't cut my panels before trying them.
[Re: cataclysm80]
#335369
06/03/09 07:01 AM
06/03/09 07:01 AM
BDW
Thx for the pic!
That looks like it will take care of the fast-down, slow-up problem. Funny it took almost 40yrs to copy the factory design.
The problem with A1 Electric is they don't have a helper spring. Even the factory manual regulators have them. Simple concept, same as your garage door. Spring winds up on the way down, slowing the decent, unwinds on the way up, helping it raise.
I spoke to the Electric Life tech support, they finally admitted this was a problem, and suggested I could add a helper spring as some of their other customers were doing.
No thanks, bad design in my mind.
[Re: jbc426]
#335370
06/03/09 04:54 PM
06/03/09 04:54 PM
DaytonaTurbo
Manitoba, Canada
These are the ones I used the first time worked great in my 87 daytona, and that car had windows that were harder to roll up/down than any other car I've owned and those motors powered it nicely. The second kit I installed was a cheaper one from one of the other sellers on ebarf, the kit looked like it used the same motors as the spal ones with different drive hardware. Installation and function is the same, they work great and are easy to install. I never had any problems with these things and I would not hesitate to use them again.
