440 Crank Bolt and Washer #334481
05/31/09 06:07 PM
05/31/09 06:07 PM
Portland Oregon
JohnnyBeGood Offline OP
Portland Oregon
What is the correct length 2.25 or 2.50 will be using fluidamper
Re: 440 Crank Bolt and Washer [Re: JohnnyBeGood] #334482
05/31/09 07:08 PM
05/31/09 07:08 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Install the dampner with a dampner installer and use the longest bolt that won't bottom out before being torqued to spec
