Help with brakes
#332678
05/29/09 06:41 PM
05/29/09 06:41 PM
Posts: 165 ohio
B5 GTX
ohio
Having trouble with spongy brakes. They are manual drum brakes, everything is new from shoes,hoses,wheel cylinder, mastercylinder. Have been bled numerous times but I still have to much pedal travel unless I pump the pedal. I did bleed the mastercylinder and then the entire system, so what am I missing? Is it the wrong mastercylinder? thanks for any scott
Re: Help with brakes
[Re: MoparTod]
#332682
05/29/09 06:53 PM
05/29/09 06:53 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
residual pressure valve not working, allowing the shoes to fully retract into the wheel cylinders?
internally leaking master cylinder?
I agree...pump them up till the pedal gets hard, and then hold pressure on it to feel if it slowly sinks to the floor.
that'll tell you if you have a leak or not
**Photobucket sucks**
[Re: MoparTod]
#332683
05/29/09 06:57 PM
05/29/09 06:57 PM
Posts: 165 ohio
B5 GTX
ohio
pedal is steady you can stand on it and it wont go down any further, just travels to far to begin with. I will check the e brake cable, and also re check the drag. I just wonder if I could have gotten the wrong master cylinder and I'm fighting a loosing battle until i change it?
thanks scott
[Re: 70Cuda383]
#332684
05/29/09 06:58 PM
05/29/09 06:58 PM
Posts: 7,506 Az
Crizila
Az
Did you check to make sure the arc on the shoes mached the arc on the drums?
Fastest 300
[Re: B5 GTX]
#332686
05/29/09 07:08 PM
05/29/09 07:08 PM
70Cuda383
Marysville, O-H-I-O
No I did not could that cause this problem?
thanks for the input guys scott
Especially on new shoes, it could be.
apparently who ever is making re-pops of the Packard brake shoes can't get a smooth finish on the shoe, so it gets high and low spots. we would set the brakes with a LOT of drag, go to the end of the parking and stop, turnaround, come back, stop, pull in, re-set the brakes, go around the block, come in, re-set the brakes, did this 3 or 4 times as the shoes were wearing down the high spots. once all the high spots were gone, it would hold fine for a long time.
[Re: B5 GTX]
#332690
05/29/09 07:46 PM
05/29/09 07:46 PM
Posts: 6,516 Santa Cruz, California
Lefty
You still have air in the system. Make sure air is not getting back into the system before you close the bleeder screw.
[Re: B5 GTX]
#332692
05/29/09 08:18 PM
05/29/09 08:18 PM
RapidRobert
yes you do need a very thin slightly bent screwdriver hold the adjuster back. It is a pita but it shifts the assy & takes all the play out & works better than just adjusting them & skipping that. W 4 wheel drums I would check the M/C(w both brass plugs) then hookup the front drums(rear M/C still capped)& adj/bleed out the front drums(wheels off ground & spin each one by hand(forward) & listen for the "tick" & adj & with your pedal then good uncap/hookup the rears & repeat.
[Re: RapidRobert]
#332693
05/29/09 09:33 PM
05/29/09 09:33 PM
Posts: 7,545 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
RRobert knows his stuff.
My two cents: - If the ONLY problem is pedal TRAVEL, and not braking ACTION, then something is not right at the drum mechanism or shoes. - If the problem is that you have a lot of TRAVEL AND POOR BRAKING action, then I think you have MC/air/bleeding issues.
Also a couple basic things, and I don't mean to imply you didn't already know this:
1. Start bleeding the brakes at the rear passenger wheel, the rear driver's then do fronts last.
2. This was already said, but worth repeating: When you open the bleeder at the drum and have your assistant apply the brakes, make sure he doesn't release the brake pedal until after you've closed the bleeder screw. Then he can lift the brake pedal for the next 'bleed'.
3. If the mechanisms at the drum are working, the automatic brake shoe advancers actuate when you travel in reverse and brake. You can usually hear the click(s). So, instead of a lot of spooning, I've had proper results letting the shoes adjust themselves tight to drum automatically by driving in reverse and braking assertively. Sometimes the adjusters aren't working tho' so try RRobert's recommendation to get that right for troubleshooting purposes.
Best, -Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: 67SATisfaction]
#332694
05/30/09 12:20 PM
05/30/09 12:20 PM
Posts: 165 ohio
B5 GTX
ohio
A big thank you to everyone for your input, the pedal is now rock hard!! it only travels a couple inches. They feel much better. I think the issue was the method I used to bleed the master cylinder, it left some air in the system, the plug method is far superior. thanks scott
