Re: Rocker ratio comparision
[Re: old_racer]
#332481
05/29/09 02:06 PM
05/29/09 02:06 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
all going to depends on if the heads can support the additional flow....
if they're lightly massaged 906's, probably not worth it. if they're full boogie SR's or eddie RPM, probably.
[Re: old_racer]
#332483
05/29/09 05:17 PM
05/29/09 05:17 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Steve D did a chassis dyno years ago, on a warmed up 440. He found a few HP over the 1.5's vs the 1.6's...I bet the old article is still up over at www.moparmusclemagazine.com I bet it would be worth less than 10 hp even on a Hot full bore race engine IMO. ![](/ubbthreads/images/graemlins/thumbs.gif)
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: old_racer]
#332484
05/29/09 05:26 PM
05/29/09 05:26 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I've done this on small blocks and most times seen a improvement.... but only increasing the intake rockers, gained nothing on the exhaust side(waste of money doing the exhaust).... unless it was a REALLY small exhaust lobe. But it will depend on your intake flow weather it will improve... I should say at what lift ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Bob_Coomer]
#332485
05/29/09 05:30 PM
05/29/09 05:30 PM
russ, you might have a clearance problem going to the 1:6 rockers with the pushrods .they might rub on the sides. i had a problem and couldnt do the swap since my motor was already assembled.
[Re: old_racer]
#332491
06/06/09 08:19 AM
06/06/09 08:19 AM
Posts: 16,932 NC
440Jim
NC
... I used 906 heads and I hogged on the intake port to get the max wedge intake to fit , ... I have a brand new set of max wedge mopar perf. heads
FYI, I am not sure, but depending what max wedge heads you have, they are suppose to use an offset rocker. Different than the 906 heads.
