COIL SPRING WEIGHT? #332456
05/29/09 12:56 PM
05/29/09 12:56 PM
Belle River
Q
QUIKFISH1850 Offline OP
Q
Belle River
I have my car on the scales front weight 1670lbs rear weight 1470lb with me in and full of fluids
what spring rate do I need I tried 250lb they are to light.
Re: COIL SPRING WEIGHT? [Re: QUIKFISH1850] #332457
05/29/09 12:59 PM
05/29/09 12:59 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
110 or 130
WAXER
Re: COIL SPRING WEIGHT? [Re: QWK_ENUF] #332458
05/29/09 01:10 PM
05/29/09 01:10 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
are you asking about front or rear springs?
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: COIL SPRING WEIGHT? [Re: QWK_ENUF] #332459
05/29/09 01:12 PM
05/29/09 01:12 PM
Belle River
Q
Q
Belle River
Sorry, I should have said front springs I have double adjustable 10" QA1 shocks the rear is done and good.
Re: COIL SPRING WEIGHT? [Re: QUIKFISH1850] #332460
05/29/09 01:17 PM
05/29/09 01:17 PM
Kissimmee Fl.
Kissimmee Fl.
the front of my car is 1507 with driver and I have 350# springs on mine and they seem border line IMO
Re: COIL SPRING WEIGHT? [Re: dusturbd340W5] #332461
05/29/09 01:50 PM
05/29/09 01:50 PM
Belle River
Q
Q
Belle River
Marginally to light or to heavy I was under the impression that they needed to be as light as possible just enough to hold the car up, the 250# i have are to soft they are almost bound up.
Re: COIL SPRING WEIGHT? [Re: QUIKFISH1850] #332462
05/29/09 02:10 PM
05/29/09 02:10 PM
Kissimmee Fl.
Kissimmee Fl.
I believe mine are a touch light but the next step is 450's and I think they would be to heavy for my car. Although my car works well the way it is so I have no reason to change things
Re: COIL SPRING WEIGHT? [Re: QUIKFISH1850] #332463
05/29/09 02:53 PM
05/29/09 02:53 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
i have 8 in 400 lbs on the front gonna try some 350 lbs later
WAXER
