magnum stroker rear main seal leak #332202
05/28/09 11:28 PM
05/28/09 11:28 PM
BC Canada
cudasam Offline OP
cudasam  Offline OP
BC Canada
has anyone had a problem with the rear main seal leaking after installing a stroker crank in a magnum. I did not use the special grooved bearing.
Re: magnum stroker rear main seal leak [Re: cudasam] #332203
05/28/09 11:41 PM
05/28/09 11:41 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Never had a leak there and I don't use the "special" grooved bearing.
