Stumped! 70 Duster front end alignment -- can't get it! #331843
05/28/09 07:39 PM
05/28/09 07:39 PM
Colorado
CuriousYella70 Offline OP
Colorado
I have done everything that I can think of and cannot get the alignment on my 70 Duster to stick. We set the ride height to where I want it, do the alignment and then take it around the block -- when we get back to the shop, its come undone -- its either sitting too high now, or too low, or one tire is leaning in too far or out too far, it just wont stick!
I was told my lower control arms were shot and torsion bars were kind of weak, i replaced them and still nothing, alignment will not stick! Everything on the front end is brand new. So what's left? Maybe a tweaked frame? I'm out of ideas!!!!
Re: Stumped! 70 Duster front end alignment -- can't get it! [Re: CuriousYella70] #331844
05/28/09 08:17 PM
05/28/09 08:17 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
I'm grasping at straws here but the lower control arm bushing bolts should not be tightened until the car is on the ground and resting at ride height.
Re: Stumped! 70 Duster front end alignment -- can't get it! [Re: TooMany62s] #331845
05/28/09 08:47 PM
05/28/09 08:47 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I had a 70 Duster years back that was kinda doing the same thing and it ended with a crack in the k member where the lower control arm bush is pressed, maybe jack it up on the lower control arms where the ball joint is and grab the wheel and try to move it top to bottom.
Mitch
Re: Stumped! 70 Duster front end alignment -- can't get it! [Re: TooMany62s] #331846
05/28/09 08:56 PM
05/28/09 08:56 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Even if the frame was bent. I'd expect your settings to stay from before and after a test drive.
The pads on the alignment rack must be free. This was allow the suspension to settle after every adjustment.
I know a tech who spent almost an hour just to set the toe. Turned out to be the pads still had the pins to hold them still in them.
Once they were free, it was a couple minutes.
Re: Stumped! 70 Duster front end alignment -- can't get it! [Re: Magnum] #331847
05/28/09 09:05 PM
05/28/09 09:05 PM
my 1st thought was that the UCA cam/bolts werent being tightened enough but there was a(similar) thread way back & iirc something was loose in the LCA or was bending & he was pulling his hair out until he caught it.
Re: Stumped! 70 Duster front end alignment -- can't get it! [Re: RapidRobert] #331848
05/28/09 10:03 PM
05/28/09 10:03 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
hi try backing t.bar ajusters with support under frame then ck for play at lower control arm pivot at k frame
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: Stumped! 70 Duster front end alignment -- can't get it! [Re: 1969gtx] #331849
05/29/09 12:53 AM
05/29/09 12:53 AM
Colorado
Colorado
someone with a Dart in my club had the same issue with her k-frame, turned out she had a crack in it and that kept her alignment from happening . . . i'll try doing everything you guys suggested!
Re: Stumped! 70 Duster front end alignment -- can't get it! [Re: CuriousYella70] #331850
05/29/09 06:29 AM
05/29/09 06:29 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I had a '70 Swinger do the same thing. The mount for the right side LCA was broken out of the K-frame. Pretty common on A bodies.
Re: Stumped! 70 Duster front end alignment -- can't get it! [Re: CuriousYella70] #331851
05/29/09 11:16 AM
05/29/09 11:16 AM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
To re-iterate [in part] what others have already said:
1. If the problem were simply inexplicable height changes, I would recommend revisiting at what height the UCA and LCA bushings were tightened (they are supposed to be left a bit loose, then tightened at normal ride height). Also, to inspect closely the REAR anchor points of the t-bars, which need to be solid and immovable in their mounts.
2. Since the problem also involves a noticeable shift in camber (which is how I interpret your description of the tire "leaning"), you need to look for something in a suspension component or attachment point that is supposed to be solid and immovable, but isn't. Something simply bent, but not shifting isn't going to cause this. Inspect carefully the point where the LCA pivot meets the K member - are there any cracks, or is the welded tube in any way loose? What about the condition of the LCA bushing itself? Continue out the LCA to the lower ball joint, looking for anything cracked, or loose. Do the same inspections on the upper ball joint and in along the UCA. Look closely at the point where the UCA eccentric bolts are. Are the bolts tight, the bushings intact, and inner fender and related structure solid and uncracked?
A thorough and careful inspection is in order. That being said, my money is on the structure at or near where the LCA pivot shaft is anchored.
Down to just a blue car now.
Re: Stumped! 70 Duster front end alignment -- can't get it! [Re: 68HemiB] #331852
05/29/09 11:18 AM
05/29/09 11:18 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
gotta be something broken, loose or too tight or a combo of each.
Re: Stumped! 70 Duster front end alignment -- can't get it! [Re: aarcuda] #331853
05/29/09 03:22 PM
05/29/09 03:22 PM
Colorado
Colorado
Well we got the Duster back on the lift and noticed from the rear that the drivers side leaf spring is twisted. From the axle back to the rear hanger the leaf spring is twisted to the left, looks like the bushings are shot and so the hanger isn't in properly. My guess is this is helping cause the alignment to not stay in place, I mean, if the backend isn't right how can the front be right?
Re: Stumped! 70 Duster front end alignment -- can't get it! [Re: CuriousYella70] #331854
05/29/09 04:07 PM
05/29/09 04:07 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Will what you describe affect the handling? Of course.
Will it contribute to the shift in camber you reported on a front wheel? Nope.
Re: Stumped! 70 Duster front end alignment -- can't get it! [Re: 68HemiB] #331855
05/29/09 05:28 PM
05/29/09 05:28 PM
michigan woods
imfixinmopars426 Offline
michigan woods
my a body had the tube cracked and loose that houses the lower a arm bushing bolt,in the k-member and the car drove really bad,lol.
Re: Stumped! 70 Duster front end alignment -- can't get it! [Re: imfixinmopars426] #331856
05/29/09 05:55 PM
05/29/09 05:55 PM
Colorado
Colorado
Well i'll check that this weekend, the tube thats located in the k-frame that the lower control arm stud goes through. Does someone repop these tubes?
Re: Stumped! 70 Duster front end alignment -- can't get it! [Re: CuriousYella70] #331857
05/29/09 06:53 PM
05/29/09 06:53 PM
Tampa Florida
MoparTod Offline
MoparTod  Offline
Tampa Florida
Do a 4wl alignment. Dont do a thrust angle. Put all four heads on so you can actually see were the rear is setting. It will show the axle positioning if your machine was built after 2000.
Re: Stumped! 70 Duster front end alignment -- can't get it! [Re: CuriousYella70] #331858
05/29/09 10:19 PM
05/29/09 10:19 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The tube doesn't crack. Its the weld that holds the tube to the K-member stamping
