The problem is only at the front of the pan where it meets the block.
I tried to use RTV and let it dry. After a month, a hairline crack formed on each side. I thought about taking it apart and using a LA gasket. I gave the corners another heavy bead of RTV and am allowing it to cure.
I will likely leave the motor in the car until winter, and will keep an eye on the results.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
