Re: Torqueflite Help
[Re: wanna72rr]
#331712
05/28/09 05:41 PM
05/28/09 05:41 PM
Posts: 26,032 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Slipping in 3rd gear is usually a problem in the front clutch but it could also be a clogged filter so it's worth a try to pull the pan and have a look-see. Running with low fluid could have fried the clutches.
If a fluid/filter change doesn't help it's due for an overhaul.
[Re: John_Kunkel]
#331713
05/28/09 05:53 PM
05/28/09 05:53 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
[Re: 383man]
#331716
05/29/09 12:42 PM
05/29/09 12:42 PM
Posts: 934 Oviedo, Florida
wanna72rr
Oviedo, Florida
It takes a few seconds to apply power to reverse gear once selected (typical on Torqueflites?) and doesn't have too much power being applied while using it ... so do you think it's the front clutch?
BTW how many quarts of fluid does a Torqueflite hold?
