Do A bodies use brake booster to firwewall gaskets #331281
05/28/09 06:55 AM
05/28/09 06:55 AM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
like B and E bodies? Years from 67-76. Any pictures?
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Do A bodies use brake booster to firwewall gaskets [Re: 71TA] #331282
05/28/09 11:58 AM
05/28/09 11:58 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
booster isnt bolted directly to the firewall, not sure if the bracket uses a gasket
Re: Do A bodies use brake booster to firwewall gaskets [Re: 05dakota] #331283
05/28/09 12:31 PM
05/28/09 12:31 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
the a body booster i have has a like a .020 thin metal plate, with a white foam gasket.
Re: Do A bodies use brake booster to firwewall gaskets [Re: ademon] #331284
05/28/09 12:35 PM
05/28/09 12:35 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
heres another pic, BTW anyone know what year booster this is?
Re: Do A bodies use brake booster to firwewall gaskets [Re: ademon] #331285
05/28/09 12:51 PM
05/28/09 12:51 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
The front has a 1/4"thick plate that the back side seals buy the rubber from the booster bladder, the front has a roundish plastic cap with a very fragile around 1/8" open cell foam.
Re: Do A bodies use brake booster to firwewall gaskets [Re: ademon] #331286
05/28/09 03:54 PM
05/28/09 03:54 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
That one looks like my 73 one
Re: Do A bodies use brake booster to firwewall gaskets [Re: 340SIX] #331287
05/28/09 09:12 PM
05/28/09 09:12 PM
wv
Dartcuda Offline
Dartcuda  Offline
wv
As well as my 73 one.
Re: Do A bodies use brake booster to firwewall gaskets [Re: Dartcuda] #331288
05/29/09 11:08 AM
05/29/09 11:08 AM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Thanks guys! What years would be similar? 67-74? I just did a 75 Duster one for a guy and it was about a 4-1/2" square one witth aabout a 2-1/2" hole in the middle and 4 stud holes in the corner. Thinking it's a 75-76 thing.
Re: Do A bodies use brake booster to firwewall gaskets [Re: ademon] #331289
05/29/09 11:33 PM
05/29/09 11:33 PM
Vista, California
ChickMaggot Offline
ChickMaggot  Offline
Vista, California
I have a booster just like that. I pulled it from a '74 Dart.
You can lead a gift horse to water, but you
can't look in his mouth.
