Who makes a Good Non Bolt in Sprag for 727? #331164
05/27/09 11:47 PM
05/27/09 11:47 PM
NW Pa.
KD800X Offline OP
KD800X  Offline OP
NW Pa.
We has a misshap with a broken Pinion Yoke in Columbus. We took the Transmission apart and the Sprag looked ok but I think we should change it never the less. I was looking in the A&A Book but it looks like all of there Sprags are bolt in. Does anyone make a good non bolt in sprag?
Re: Who makes a Good Non Bolt in Sprag for 727? [Re: KD800X] #331165
05/28/09 12:09 AM
05/28/09 12:09 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
if you remove the original sprag you want to use a bolt in as nothing fits as good as the first time it was installed at the factory . get the A+A ultimate sprag , anything else is wasting your money .
But if the race is tight inthe case and not all galled up I would just replace the rollers and springs .
is this a street car , race car , autio VB or manual ?
Re: Who makes a Good Non Bolt in Sprag for 727? [Re: JohnRR] #331166
05/28/09 12:14 AM
05/28/09 12:14 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
what makes an ultimate sprag better?
Re: Who makes a Good Non Bolt in Sprag for 727? [Re: Quicksilver440] #331167
05/28/09 12:24 AM
05/28/09 12:24 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It has more rollers and springs and makes it virtually impossible for the rollers to roll over , the rollers are a little smaller in size but there are more of them .
Re: Who makes a Good Non Bolt in Sprag for 727? [Re: JohnRR] #331168
05/28/09 12:35 AM
05/28/09 12:35 AM
NW Pa.
KD800X Offline OP
KD800X  Offline OP
NW Pa.
It's a Race Car 9.80's Hemi Coronet. We really don't want to get into drilling the case for the bolt in. The guy doing our Transmission said the Sprag looked good, I just felt that while we have it apart we might as well put a new one in. If changing the Springs and Rollers will help than thats is an idea.
Re: Who makes a Good Non Bolt in Sprag for 727? [Re: KD800X] #331169
05/28/09 01:26 AM
05/28/09 01:26 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
press in an Ultimate sprag, just don't drill & bolt it. but since you're changing it you should go the full monte & do it right. as said earlier, nothing fits as good as the original. drilling 6 holes is great insurance.
Re: Who makes a Good Non Bolt in Sprag for 727? [Re: KD800X] #331170
05/28/09 02:00 AM
05/28/09 02:00 AM
Chicagoland
chargerron69 Offline
Chicagoland
the regular bolt in doesnt require any drilling at all the ultimate needs 2 holes drilled. if you dont have any kinda bolt in sprag at all you are racing a time bomb! sprag failure is the reason 727 grenade
67 Coronet 383 hogged out 906's 727 430 dana best 10.48 @126.80 1.47 60 on fogger same car pump gas 605 wedge 9.98 @ 138.42 1.50 60 on wore out 9 inch radial slick ss springs and frame connectors its got more in it!!! 72 Newport 2 door 400 727 85 Ram 440 4 speed O/D 3.54 dana
Re: Who makes a Good Non Bolt in Sprag for 727? [Re: KD800X] #331171
05/28/09 02:31 AM
05/28/09 02:31 AM
Arkansas
JoWeTu_6 Offline
JoWeTu_6  Offline
Arkansas
You realy should go with the bolt in. Do a srarch in mopar action I belive and see what happens when a 727 lets go it's like a bomb going off under the car when the sprag takes a dump and it will sooner or later.
You see it's not a question of will it go away it will, it's when, and for that thing it's always the wrong time.
Always take the side of safty bolt in is the only way to go.
JoWeTu_6
Re: Who makes a Good Non Bolt in Sprag for 727? [Re: JoWeTu_6] #331172
05/28/09 04:56 AM
05/28/09 04:56 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Mopar Enthusiast Article Torqueflite Built Right
This might answer alot of your questions - I think it's about 6-8 pages long
Are you running a stock drum too?
Re: Who makes a Good Non Bolt in Sprag for 727? [Re: DJVCuda] #331173
05/28/09 07:12 AM
05/28/09 07:12 AM
KEVIN,i just took my 727 apart,my aluminum drum was worn alittle, i am replacing my drum with a billet steel one and while my drum is apart i am changing to a BOLT IN SPRAG, for $175.00 its a no brainer.
without a bolt in sprag, its a matter of time before that tranny lets loose and goes through your floor cutting off dads leg.
with the power you making now, you have to really upgrade your parts correctly to avoid an accident that can be prevented, build it right the 1st time, it will save you money and aggravation later on.
Re: Who makes a Good Non Bolt in Sprag for 727? #331174
05/28/09 08:32 AM
05/28/09 08:32 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We usually only replace the springs and rollers,about $25.We do use the bolt in overrunning clutch if there is damage to the the inner or outer support rings.The bolts that hold the clutch(sprag) in place do nothing to stop the it from "exploding" If it is going to happen(usually from abuse or incorrect use or other drive line breakage)The new A&A and other "Super Sprages" with more springs and rollers may increase the life of the unit.If your set on replacing it,I would recommend A&A,Rick is a great guy and supports the site and Mopar racers.
Re: Who makes a Good Non Bolt in Sprag for 727? [Re: KD800X] #331175
05/28/09 08:41 AM
05/28/09 08:41 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
You just use the 4 existing holes for the rear support (changing the bolts long enough for the sprag and not bother drilling the holes for the extra twp bolts.
Re: Who makes a Good Non Bolt in Sprag for 727? [Re: B G Racing] #331176
05/28/09 08:58 AM
05/28/09 08:58 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
FINALLY!!! A voice of reason!
Re: Who makes a Good Non Bolt in Sprag for 727? [Re: J_BODY] #331177
05/28/09 09:09 AM
05/28/09 09:09 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
this is absolutly correct and for info the ultimate sprag from Coan uses the 4 holes in the case with nice shoulder bolts.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Who makes a Good Non Bolt in Sprag for 727? [Re: dusturbd340W5] #331178
05/28/09 09:57 AM
05/28/09 09:57 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
The only problem with the one that Coan uses is the shouldered bolt is necked down to a 1/4 thread and fastener and the srings and rollers are so small that I always find broken springs and flat rollers.I still preferr the stock style large springs and rollers.
Re: Who makes a Good Non Bolt in Sprag for 727? [Re: B G Racing] #331179
05/28/09 10:17 AM
05/28/09 10:17 AM
Kissimmee Fl.
Kissimmee Fl.
Thats interesting because the sprag they use is a low/rev sprag from a ford C-6/E40d trans and we dont see them fail very offten
Re: Who makes a Good Non Bolt in Sprag for 727? [Re: KD800X] #331180
05/28/09 10:33 AM
05/28/09 10:33 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Since it's a drag car I wouldn't change out the orignal unless it's damaged , if you want to change it anyway use the A+A. You don't really need to drill for the 2 extra bolts, later 727's have a 6 bolt rear support in that case you don't have to do much drilling if that's the case you have. BUT if you just change the springs and rollers buy the A+A billet drum, or go with an Alum drum, either way if the srag fails you won't end up with the trans coming thru the floor .
Re: Who makes a Good Non Bolt in Sprag for 727? [Re: dusturbd340W5] #331181
05/28/09 10:39 AM
05/28/09 10:39 AM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
I cast my vote for the OEM stuff. Those parts have worked for nearly 50 years ...and even under the abuse of a Clutch-flite.
Now when a company comes out with a sprag and will GUARANTEE it .....
THEN ...I might change-my-mind.
Re: Who makes a Good Non Bolt in Sprag for 727? [Re: dOc !] #331182
05/28/09 10:45 AM
05/28/09 10:45 AM
Arkansas
JoWeTu_6 Offline
JoWeTu_6  Offline
Arkansas
I found this link in a post by John_Kunkel
You all should take a look at it, it's self explanatory.
http://good-times.webshots.com/album/563387085NzMVcm
JoWeTu_6
Re: Who makes a Good Non Bolt in Sprag for 727? [Re: JohnRR] #331183
05/28/09 10:52 AM
05/28/09 10:52 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
If you don't have a billet drum in it now get one.
Don't let this happen to you.
