Re: Carter Thermoquad Rebuild Kits?
[Re: NachoRT74]
#330711
05/29/09 09:42 PM
05/29/09 09:42 PM
Posts: 7,538 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
Most of the kits I have bought from Larry were Walker.
In your situation, I can imagine the difficulty you must have after using parts from 7 different carbs - you might not know if the base plate came from a '69 383 B-body w/AC, and the top plate off a '70 C-body automatic.... the bores may line up but the metering might be different top vs bottom,...no?
And THAT's a difficult carb to find one kit for .. so maybe you ARE better off trying your parts bin and just trying until it works...
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: 67SATisfaction]
#330712
05/29/09 09:48 PM
05/29/09 09:48 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
yes, well, I have an advantage, FOR SURE all carbs are post 72s, since no one TQ was used on earliers, beside some 340s and I have keep matched the top and bottom plates, just checking for plastic bowl similarities, and linkages. is not hard to guess what plastic body goes on which carb just checking for the emissions controls stuff blocking or not. after 8-10 years dealing with these I still can not say I know about this ( probably will never know about this ), but I have learnt something I think
[Re: 68CoronetRT]
#330713
05/29/09 10:05 PM
05/29/09 10:05 PM
Posts: 5,270 Missouri
MY340
Missouri
NAPA sells them for less than $30 without floats but you get everything else. Of course they have floats too for them. It includes both 1 thick and 2 thin base gaskets. #657-C I believe is the number.
1970 FE5 Duster 360/904/3.91's SOLD
1973 TB3 SpaceDuster 340/4spd/4.10's SOLD
Moparless for now but when the opportunity is right I'll have another one.
[Re: MY340]
#330714
05/29/09 10:14 PM
05/29/09 10:14 PM
NachoRT74
Valencia, España
yes thats the PN, I know thanks... that't the one being sold down here on mercadolibre.com ( same as ebay but local ), but B on box instead C... hygrade, dunno the diff on the last letter... maybe the size of the kit ? ( with or without floaters or whatever ) http://www.mercadolibre.com.ve/jm/item?site=MLV&id=11841519ok, got the O ring PN at the invoice.. is One of these: QR-4011 or QR-4108 more toward on the first one. I got both to check wich one was the best fit and as far I remember was the first one. it was SAME outer and inner diameter... slightly and ALLMOST UNAPRECIABLE thickness size ( if some diff really ). TRUST ME they WORK!!!! the second one ( if I'm right )was too thick and got broken when mounting... too much compression over the O ring
[Re: NachoRT74]
#330715
05/29/09 10:25 PM
05/29/09 10:25 PM
NachoRT74
Valencia, España
how many O rings do you want ?
[Re: NachoRT74]
#330716
05/29/09 10:29 PM
05/29/09 10:29 PM
NachoRT74
Valencia, España
believe or not THE TWO AT THE BOTTOM of pic are new and ORIGINALS!!! from rebuild kits. you can easily note the diff size of both EVEN ON THICKNESS, so as far you find an O ring that fits you won't have any problem to replace the old one... and gas/oil resistant of course.
the two above were selected to replacements, the one above them was obviouslly discarded ( is one of the PN I provided )
Forgett the caliper to compare them then LOL.
sorry the bad quality pic, is cell phone and at night.
[Re: bigblock340power]
#330720
02/03/13 01:18 PM
02/03/13 01:18 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
I just need the brass floats. Who, where, how do I order, and how much? Thanks.
got a pair from Napa a year ago.
