Re: Pick my rear end gear ratio.
[Re: dustyswinger]
#330015
05/26/09 11:49 PM
05/26/09 11:49 PM
Posts: 396 California, USA
Phil Saran
California, USA
Craig,
You may want to go back to 4:56 or even 4:88. I have a buddy with a similar combo to yours, but with 4:30 gears.
His motor is a 408 stroker, Edelbrock aluminum heads that have been ported, a much bigger carb than you run, compression similar to the 11.5 you are looking at, similar stall convertor, 904 trans with low gears. Car is somewhat heavy at around 3400 lbs (67 Cuda FB)but it's best runs have been 10.98 @ 121 at Vegas and then 10.92 @ 123 at Fontana CA
Phil Saran
Parker, Colorado
[Re: Phil Saran]
#330016
05/27/09 06:58 AM
05/27/09 06:58 AM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
IMO the 4.30 gear is one of the best overall 1/8th mile, 1/4 mile gears around.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: S/ST 3040]
#330021
05/31/09 03:32 PM
05/31/09 03:32 PM
Posts: 523 MN
dustyswinger
MN
Cam is a .600 lift with 268 duration mechanical, car weighs 3165 with me in it and the convertor is a dynamic 9 1/2 with 4200 stall. 1 7/8 headers, 950 hp holley and MSD ign.
[Re: S/ST 3040]
#330023
05/31/09 04:39 PM
05/31/09 04:39 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
4.10's on a 28" tire and a stroker seems to be on the fastest smallblock stroker a-bodies around here.. so with 30" id say 4.30 should work well.and keep that converter effecient..fwiw.. cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: dustyswinger]
#330025
08/24/09 07:28 PM
08/24/09 07:28 PM
Posts: 15,491 the boonies
aarcuda
the boonies
wow, that cam and only 9.8:1 compression... what cam is that? I might want to try it
[Re: aarcuda]
#330028
08/25/09 12:47 AM
08/25/09 12:47 AM
Posts: 523 MN
dustyswinger
MN
AAR cuda it was a cam motion cam they speced out for my application. If you want specs let me know. fastboy73@aol.comPBody. I believe it went through at about 7000 before
