Viscous fan clearance
#329551
05/26/09 04:55 PM
05/26/09 04:55 PM
Hi,
Looking for some advice please.
The car is a 69 Satellite with a 440. The radiator, if I have checked the numbers correctly, is out of a big block 72-74 Roadrunner and is 22 inch wide. It has a proper fan shroud on it.
At present, the car has a fixed (non viscous) six blade fan. The fan is approximately 16 1/2 to 17 inch in diameter. The fan blades sit about 1/2 inch outside the rear face of the shroud.
I didn't thikk this was too efficient a setup, but, here in the UK, the car runs fine at 190 degrees and stays there quite stably, even when idling in what little traffic it has ever needed to idle in.
I got from a Moparts member (thanks John) a seven blade 18 1/2 inch fan with a viscous coupling. I bolted this in this evening and the front of the viscous coupling comes pretty close to the radiator, maybe just over 1/4 inch. The blades sit very nicely within the shroud now though.
Is 1/4 inch too close ?
The car has new engine mounts and the driver's side one is one of Schumaker's Poly Locs (so the car builder told me) plus, I have fitted one of Schumaker's torque straps.
With these on the engine, is the 1/4 inch gap okay ?
I seem to have gone from too small and too far away to big enough but maybe too close.
Any advice appreciated.
Thanks.
Sandy
Re: Viscous fan clearance
#329552
05/26/09 05:06 PM
05/26/09 05:06 PM
Posts: 277 MN
Willie68coronet
MN
Sounds fine to me. My coronet has the visciou fan with the same clearance to the radiator and has never hit. Its been running fine since '02
edit actually i mesured it tonight at about a 1/2 inch so 1/4 might be too close
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
[Re: Mr.Yuck]
#329556
05/26/09 05:27 PM
05/26/09 05:27 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
This one is from a Jag, no cooling problems. And the reason it is closer to the radiator is because the radiator is a 4 core.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#329557
05/27/09 12:46 AM
05/27/09 12:46 AM
Posts: 851 Avondale AZ
Prodart440
Avondale AZ
Mine on my roadrunner is just less than 1/4" from the radiator. I have never had any problems. Been running this way since about 1991.
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
