Stihl chainsaws, who has 'em and...
#3290179
02/17/25 08:35 PM
02/17/25 08:35 PM
Posts: 21,635 in a cattle trailer down by th...
Guitar Jones
how do you start yours when it's cold and been sitting for months? I've got two, an MS162 and an MS291. The little one isn't too bad, the big one is a beast to start, both run and work great after you get them running. I've had the little one for eight years, the big one is only two years old. Any help, ideas and suggestions are welcome. Thanks.
"Come get your wife"
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
Re: Still chainsaws, who has 'em and...
[Re: Guitar Jones]
#3290181
02/17/25 08:42 PM
02/17/25 08:42 PM
Posts: 13,723 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
Run good oil that has storage as part of it's make up and when mine sit for very long, I give them a whiff of starting fluid or WD40. But just a whiff. Saves a lot of pulling.
Master, again and still
[Re: DaveRS23]
#3290182
02/17/25 08:47 PM
02/17/25 08:47 PM
Guitar Jones
I'm using either Stihl or VP premixed fuel. Been thinking about some starting fluid but was a little hesitant. Thanks
[Re: Guitar Jones]
#3290190
02/17/25 09:15 PM
02/17/25 09:15 PM
Posts: 21,841 N.E. OHIO, USA
A12
N.E. OHIO, USA
I'm a Stihl certified Silver Level Tech and here is what I teach to a customer and especially if they are a first time customer of a Stihl (or any brand for that matter).
Make sure there is fresh or good pre-mix in the tank. If not dump it and put in some Motomix Stihl 93 octane gas. Assuming the pickup (fuel) filter is good the next step is the actual normal first step
PUT CHAIN LOCK ON push lever forward!!
1. Compress the top safety lever and squeeze the throttle trigger fully and hold it wide open and move the choke/start/stop lever to full choke position and hold it there then release your finger from the full throttle position and this will lock the full choke into position.
2. Pull the start pull cord 1 or 2 briskly or until you hear or feel a "pop" from the engine, the engine is now primed (more on this in a few), Even if the saw has a primer (bulb) the full choke ONE "pop" is all you need for priming.
3. Now put the start/stop/run lever into the secondary choke or partial choke position and pull the starter cord briskly and it should start and run at or around 5k rpm.
4. Let it run with the chain lock on until you can feel some warm exhaust coming out the muffler then blip the throttle, and it should idle on its own,
In short, lock it into full choke position, pull cord one or more times until you hear or feel a "pop". Put choke into the half or partial position, then pull starter.
Mike
rsblnk.jpg)
[Re: Guitar Jones]
#3290192
02/17/25 09:23 PM
02/17/25 09:23 PM
DaveRS23
Benton, IL.
I'm using either Stihl or VP premixed fuel. Been thinking about some starting fluid but was a little hesitant. Thanks Sneak up on it. A little is certainly better than a lot. I don't use my saws much. So they often sit weeks and even months at a time. Consequently, I use the starting fluid to start them more often than not. My bigger Stihl I have had for 20 years or more.
[Re: A12]
#3290199
02/17/25 09:36 PM
02/17/25 09:36 PM
Guitar Jones
Mike
I am fully aware of the official starting procedure, but lets be perfectly honest, 1 or 2 pulls never works, in fact 20 pulls don't work without some mechanical gymnastics or sorcery.
[Re: Guitar Jones]
#3290202
02/17/25 10:23 PM
02/17/25 10:23 PM
A12
N.E. OHIO, USA
Then there's something wrong like a bad carburetor, coil etc., Just saying from my 60+ years of experience with 2-strokes, from 2-stroke motorcycles of 50cc to 550cc for a major manufacturer for 34-years as the technical manager and then on to a Stihl tech for the last 14-years. You don't know how many new and used chainsaws, trimmers, blowers, hedge trimmers, etc., I've started without doing anything but the procedure I described after being told "It won't start". At the most it ever takes is a new spark because it was soaked (fouled) because the previous person didn't use the correct starting procedure. Just saying I've done this for a living for decades. If I can't start a 2-stroke garden piece using this method then there is some adjust or mechanical issue. If it ran when you last used it then as long as the gas is good then it's the fuel has gummed up the fuel system or the spark plug is fouled.
If you think it might be a gummed-up carb and fuel system, then try some Stihl already mixed 93 octane ethanol free Motomix. What's best about it is the consistency of the perfect 50 to 1 ratio mix, premium gas 93 octane and ethanol free. Also there's VP Fix-It you can mix 50/50 with Motomix. Just trying to help.
Mike
[Re: A12]
#3290204
02/17/25 10:30 PM
02/17/25 10:30 PM
A12
N.E. OHIO, USA
https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/3168294/Searchpage/1/Main/258589/Words/%2BStihl/Search/true/re-1-year-old-stihl-chainsaw-wont-start.html#Post3168294
Originally Posted by A12 Quote Only problem is it does not have a primer bulb. Wish it did.
Doesn't matter, when your pulling the start cord in the full choke position you're "primming" the carburetor in that mode. Eliminate primer step #1 and start (pun) with #2. New out of the box saws, trimmers, etc., without a primer are "primed" this way. We were instructed not to have the customer present during the first start because it sometimes takes a lot of "priming" and it may look like the unit is hard to start because of the first prime. Full choke "prime" until you hear or feel the first "pop", (only one pop! and) then to the partial choke and it will fire up.....going out on a limb (pun again) from hundreds of times doing this.
Great! That is kinda where I was heading. This last time I did 2 pulls with choke and 4 without. Started on the 6th overall pull.
[Re: Guitar Jones]
#3290209
02/17/25 10:45 PM
02/17/25 10:45 PM
Posts: 3,784 N.W. Florida
Fat_Mike
N.W. Florida
I am fully aware of the official starting procedure, but lets be perfectly honest, 1 or 2 pulls never works, in fact 20 pulls don't work without some mechanical gymnastics or sorcery. So it's only 2 years old. Has it always been that hard to start?
[Re: Fat_Mike]
#3290225
02/18/25 12:25 AM
02/18/25 12:25 AM
Posts: 10,514 Someplace you aren't
SomeCarGuy
I’ve had mine for probably 8 years now. I store it with stabil 360 in it and start it spring and fall if not used. It basically pops off like the one guy posted. Sure sounds like a carb issue.
I want my fair share
[Re: A12]
#3290229
02/18/25 01:46 AM
02/18/25 01:46 AM
Guitar Jones
Mike Did you read my post and what fuel I'm using? They both run and idle fine after starting, I drain the fuel out when I'm done using them, I have no other issues with them other than getting them started after they have been sitting for several months and it is cold outside, like the other day it was 23°. Neither one of these chain saws have more than 10 hours use on them, and they both act the same way. Probably wouldn't be an issue if I was still in Florida.
[Re: Cab_Burge]
#3290230
02/18/25 01:49 AM
02/18/25 01:49 AM
Guitar Jones
You may be on to something. However I don't always know ahead of time if I need to cut a tree that has fallen across the road until I get there.
[Re: Fat_Mike]
#3290231
02/18/25 01:50 AM
02/18/25 01:50 AM
Guitar Jones
I am fully aware of the official starting procedure, but lets be perfectly honest, 1 or 2 pulls never works, in fact 20 pulls don't work without some mechanical gymnastics or sorcery. So it's only 2 years old. Has it always been that hard to start? Yes, both of them when cold outside and they've been sitting.
[Re: SomeCarGuy]
#3290232
02/18/25 01:53 AM
02/18/25 01:53 AM
A12
N.E. OHIO, USA
I’ve had mine for probably 8 years now. I store it with stabil 360 in it and start it spring and fall if not used. It basically pops off like the one guy posted. Sure sounds like a carb issue. I've had a Stihl 024 chainsaw since 1983 and a few other Stihl items (BG60 blower, 2 trimmers) and added another Stihl chainsaw and BGA85 blower, electric corded hedge trimmer. The 024 chainsaw and the two trimmers were from a Stihl engineer I became friends with in '83 as he put me on his product testing and evaluation list and would send me "sample" products to give him feedback.
[Re: A12]
#3290245
02/18/25 08:19 AM
02/18/25 08:19 AM
Posts: 11,030 Nort Cackalacky
rrbrucea
Member known as the "Artist"
Nort Cackalacky
Good to see you Mike. My bride works in the office at the Stihl warehouse here in Mebane, NC. She loves working for the company! And yes, we have a few pieces of Stihl equipment and are slowly gathering more. 👍
[Re: Guitar Jones]
#3290263
02/18/25 09:49 AM
02/18/25 09:49 AM
DaveRS23
Benton, IL.
Another thing we used to do way back when we rode our Yamaha dirt bikes in the winter (yeah, it's been a long, long time ago) we would pull the spark plug and heat up the electrode with a lighter or on the gas stove. Particularly for well worn bikes, that would be the difference between whether they would start or not. Remember too, that 2 strokes have to 'charge' the crankcase in order to push the fuel mixture up to the combustion chamber. Depending on a number of factors, that can take a crank or two all by itself. Newer stuff is also metered leaner than the older stuff. (thank you greenies) Yesterday it was real cold here. My nearly new fuel injected Honda side by side did not want to start. Almost run out of battery. A common complaint on them. And that is of course a 4 stroke. Maybe the new EPA rules will allow a 'tune' for it that will eliminate that issue.
[Re: Guitar Jones]
#3290352
02/18/25 08:30 PM
02/18/25 08:30 PM
Posts: 10,694 Rittman Ohio
fourgearsavoy
Rittman Ohio
If you don't know the basic principles of how a gasoline engine works you should probably get an electric saw. I thought you were some kind of a mechanic from some of your posts.
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
